Question about Mitsubishi WS-65909 65" Rear Projection Television
Picture bends in different colors
My WS-65909 Diamond Series TV picture looks like a 3D with green red and other colors bending across the screen any suggestions on how to fix?
  • wdavidrankin Feb 26, 2009
    My Mitsubishi WS-65909 started the same now it is one green color with only a faint image. The sound is there, but not picture. A repair person came out and told me that it needed a new mother board and the blue lamp needed replacing. He only looked at it from the front and took a peek in side. Is there any hope of me fixing it myself? Dave
    Scholar:
  • 33 Answers
Your Convergence IC chips and resistors arre failing you need to replace them
below is a general disscussion post for a Philips TV which will help you to understand your situation and what you might need usally you will need (2) IC convergence Chips and usally (12) Resisitors what have to be soldered onthe the board after you remove the old ones. this fix usally cost you to do it yourself $30, to have a repair man do it cost around $300-450 a new board if avalible usally costs $250-300
Sorry, for the bad new I hope you have a friend that knows how to work on circuit boards...
good luck,
below is a general post about a philips TV Convergence problem you can read about keep inmind your CHIP and RESISTORS will proball be different type....
you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Posted on Nov 20, 2008
We have a Mitsubishi diamond seriies ws 65909, we heard a pop noise (as if a speaker had blown but we still have sounds then the TV went to a rainbowish of colors and you view the picture as if it's 2...
This model uses a single convergence chip that after age fails.
I will attach some photos of the part, and also typical convergence problems.
The repair can be a do it yourself job if someone can solder etc.
The suspect part if it is a convergence problem is a SKT393-110(ABOUT A 15 DOLLAR PART ON EBAY).
If you are able I have start to finish step by step instructions for this repair that tell you everything you will need and how to do the repair.
Look at the photos and let me know.
sd tech
This is the part if it is a convergence problem.
No two sets will look exactly the same but the photos should tell you if it is a convergence trouble or not.
Steve
Sep 22, 2011 | Mitsubishi WS-65909 65" Rear Projection...
The picture bends at the top and the bottom of the screen and is blurry where it bends at
The tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
The red field on the screen, bends within the image, creating a 3D like effect.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingnment,have colors shadows pictures or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,require replacing to fix the tv picture convergence problems.The shop,will cost $300-350 for parts and labors.
Oct 19, 2010 | Mitsubishi WS-65712 65" Rear Projection...
3d look with little bending in bottom left corner of screen.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2010 | Hitachi 52LDX99B 52" Rear Projection...
Kpr-46cx10 picture issues
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 05, 2010 | Televison & Video
3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
May 26, 2009 | RCA R56WH76 Projection Television
Text/images overlap each other in 3 colors, 3D distorted picture
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture is bending at the top and bottom and looks 3d
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
Dec 15, 2008 | Samsung PCN5425R 54" Rear Projection...
Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-65909
I suspects you have bad convergance IC's
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
321 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
