Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Refrigerator will not cool
Refrierator is just over a year old. My son raised the temp control to 70, now I cannot get the temperature to go back down. The freezer works fine. There is power, lights work, doors seal fine.
  • 2 more comments
  • elderk Jan 04, 2008
    Frigidaire PHSC39EESS Stainless Steel Side by Side Refrigerator
    We have had our 1 year old refrigerator go off twice and not come back on. The first time it was during a thunder storm, the second time we were out of town and lost everything. We had to unplug it both times to get it back on. The lights on the front don't go off. Any ideas what is wrong?
  • Lisa O'daniel
    Lisa O'daniel Feb 21, 2008
    I have my fridge set at 7(max) and I can't get it below 42 degrees. The freezer is fine. Our milk keeps spoiling.
  • lporrone Jun 02, 2008
    As others described, suddenly my fridge won't cool, but my freezer is just fine. What gives?
  • Anonymous Mar 21, 2014
    For over a month the display light which shows temperature stays on. There is no alarm, the seals are fine. Can't get it to turn off and cannot find service person whop will return call. Manufacturer says it only stays on if a seal is compromised, no seal has been compromised. Help??
  • 237 Answers
Do you mean the display won't go below 70 or that the actual temps won't go below 70? First try to unplug the refer for 20-30 seconds then plug it back in. Hopefully that will reset the levels to factory settings (usually around 0 for freezer and 36 for refer).
Posted on Dec 20, 2006
SOURCE:
Adjusting freezer temperature
My name is Peter, retired Sears Home Services Tech. The freezer temp should be between 1 & -2 Deg. F, the fresh food section should be 35-40 Deg. F. I think you may have other problems if the unit does not hold temp. 70% of my service calls were either Samsung or LG. Samsung should stick with televisions.
Oct 11, 2014 | Samsung RF28HDEDBSR RF28HDEDBSR French...
Www frigidaire com MY FFHS2313LM6 the temperature is sky high and won't cool down.
Thank you for your post, friend!
I see your Frigidaire refrigerator is not cooling and you have performed a reset on your appliance by unplugging it. You could be experiencing an issue within your control panel or sealed system. I would recommend seeking assistance from a professional to come and diagnose your appliance for the proper repair. Hopefully this is helpful. -Matt
Aug 25, 2014 | Frigidaire FFHS2313LM 22.6 cu. ft. Side By...
Our GE side-by-side refrigerator (model GS225) is not cooling. Freezer is at 55 degrees and the refrigerator is at 70 degrees. The fan condensor in the back was dirty so we cleaned it. Could that be the...
Check the compressor relay. All fans should be running when the compressor is except during post dwell. In post dwell the compressor and fan con on but the inside ones do not come on for a specified time. SEE ADC how it works.
You can use the diagnostics found in this GSS SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 02, 2010 | GE Refrigerators
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Indoor unit coil air temperature 60F - 70F after R22 charge..
Clean the outside and inside coils and filter. This could be an air flow problem
Aug 21, 2009 | Sanyo Split System Air Conditioner
also the complete mod number would help
May 21, 2008 | Refrigerators
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
299 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
