Question about Dirt Devil M1100009 Reaction Soft Touch Cyclonic Upright Vacuum Cleaner Vacuum
Both chambers parts aren't spinning in DD Reaction
I have a Dirt Devil Reaction. Haven't had it long but it was given to me (new) but without a manual. I've now read the manual online but still...It has two chambers, both with air directors that are supposed to spin. It goes on and on about its dual whatever but only one of the chambers has a spinning part and fluff only seems to end up in one.
How can I get both chambers to work equally?
Thanks
  • 126 Answers
SOURCE: Dirt Devil Repair
Any warranty dealer for Dirt Devil should be able to supply a schematic for that machine. They have access to the dealer web site and can download the information.
Posted on Feb 02, 2008
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Posted on Jan 15, 2009
SOURCE: dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Posted on Jan 16, 2009
  • 8 Answers
SOURCE: no clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Posted on Jun 12, 2009
  • 294 Answers
SOURCE: my dirt devil reaction is
Sound like you have an obstruction in the suction path. check the foot (bottom) check for suction at the hose for blockage. the blockage is where you lose suction.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Oct 11, 2009
How do you separate the top of the canister from the bottom? Dirt Devil Reaction. There is dirt trapped in the top section and it needs to be cleaned.
Hold the top firmly, and twist the bottom of the canister anti -clockwise and you will be able to clean. Re-assemble by lining up both parts and twisting clockwise to lock!
Jul 05, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
How to clean/lubricate bearings on Dirt Devil motor?
If you know some one with compressed air blow out all dirt particles best as possible then get a 3 in 1 oil or sewing machine oil drip along the motor shaft and turn by hand you will be able to free the difference once lubricated it should only take a few drops per side . let set for awhile and repeat . then put her together and see if motor speed returns to normal . also check turbine wheel for slipping on shaft.
May 01, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
Needs a new motor. Where can I find one?
Most vacuum repair shops can order them. Or you can try on-line. I believe other M084000 series motors should be compatible. You may be better off buying a new vacuum.
You can contact the DD site to find out what motor to order.
http://www.dirtdevil.com/
The following link provides the parts diagram and part number for a motor for MO84500, which I believe may be similar enough to use.
http://www.ereplacementparts.com/dirt-devil-m084500v-vibe-bagless-quick-vac-parts-c-36976_37103_37227.html
Mar 05, 2011 | Dirt Devil M084000 RoomMate Upright Vacuum
How do i clean the two little top parts above the bottom empty dirt cup
hi there,
inside the dirt chamber you should be able to twist and remove both of the silver what look like arrowheads and you should be able to get up inside the top with a water hose to clean out the upper area there. Allow for the unit to dry before you put it back together.
Good luck.
Mark
Nov 09, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
My dirt devil reaction is spitting out dirt everywhere. how do i fix this?
Oct 10, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
No clogs, work fine, but makes a very loud wailing sound? what could it be?
Apr 17, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Dirt Devil Repair
Jan 27, 2008 | Kenmore Progressive Bagless Upright with...
Brush on/off lever
Replacing a belt or how to get into the vacuum cleaner . It is a Dirt devil Reaction D2
Oct 09, 2007 | Dirt Devil M1100009 Reaction Soft Touch...
Dirt Devil M1100009 Reaction Soft Touch Cyclonic Upright Vacuum Cleaner Vacuum Logo
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
