Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9150pw3 is dead
Hi, i'm getting no light or code, a service man came and suggested to replace the microcontroller board which i did.
First, when i installed the board, i got the front panel to work, but when i tried to run it, it dies again. I thought i heard something poped. So, could the problem related to another board?
thank you.
Joey, Corona, Ca
    Genius:
  • 1,028 Answers
Most likely the interface panel(all the buttons and do dads)..there is more to interface than just buttons there are several electronic items there too besides i did the same thing and had to go back to change controls
Posted on Nov 21, 2008
Microwave oven dead
Check the fuse in the microwave it is probably open, unplug and remove the top, follow the leads from the keyboard to the circuit board, look for a silver rectangular capacitor, short out the two pins to remove any high voltage, now look for a small fuse that is clipped in, pop it out and check if open, replace with same current rating. The door switches in most cases cause the fuse to blow, normally one switch is defective.
Mar 17, 2012 | Panasonic Microwave Ovens
Some of the keys of my lenovo G450 laptop are not working.what to do now?
Hello
What may have happened is that when you grabbed it, the pressure could have broken a trace (printed wire) on the printed circuit board in the keyboard. Usually the way a keyboard works is by making a matrix of switches where, for example, "a", "z", "q", "1", "`", and "tab" could be on one column and "z", "x", "c", etc are on one row. Pushing the "z" key makes a connection between the the corresponding row and column, and the keyboard's microcontroller interprets that as a keypress on the "z" key. If you've broken the connection to the "qaz" column, the microcontroller will never know that you've pressed one of those keys. Replacing the keyboard will give you a new microcontroller and circuit board, so you should be good to go!
Do rate the solution if helps
Good Luck
Dec 30, 2010 | Lenovo Computers & Internet
Blank screen, blinking blue light on front
When a unit shows these symptoms it generally indicates that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | JVC HD-56FN97 56" Television
T642 Laser Pinter
This is a call for service message generally requiring professional repair.
There are generally only four reasons:
No power, Check fan power leads as one may have slipped off it's fitting
Jammed: Either too dirty or a shred of paper may be blocking the blades, pull free and clean off with compressed gas(no more than 25ft/lbs)
Dead fan: Call a repair man or call lexmark and give them the exact code,they will identify the fan and can sell you the part.
Dead controller board: as with above call a repair man or lexmark with code and order spare part.
The only bad news other than you may need a repairman, if you order the fan or controller board it may be the other and no way to know ahead in some cases.
The good news, if you're still under warranty, lexmark has good repairmen and fast response times in most areas.
Either way, Hope this helps FixYa,
Chris
May 10, 2009 | Lexmark T642 Laser Printer
Vacuum faulty power PCB, Need service manual/schematic
No schematic found. The Q1 transistor is a 2N3904, D3 was replaced with a 1N4000 series.
Root cause still Unknown, but Q1 is an exact match and D3 is an acceptible replacement.
Hoovers solution is to replace the whole PCB no matter whats wrong with it, what a waste or good technology!
Mar 30, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Power Surge damage. Suggestions on which part to replace.
You probably have a sacrificial diode that blew out to save the rest of the monitor from further damage. The manufacturer should replace it with a refurbished one at little and sometimes no charge (comparatively speaking).
May 08, 2008 | Computers & Internet
Do you fix Astar POWER SUPPLY UNIT for a ltv-32asb I had 4 caps. replaced and it is still dead?
Sorry, But we don't take boards in to finx them without the sets. Thanks for asking and I am sorry I can't help in this one. A quick suggestion is to chack all the doides on the PS Board. I find that a dead diode is the major cause is a failure.
Good Luck
Ed ( Radio Man )
NC Electronic
Mills, Wyo
307-266-4675
May 08, 2008 | Astar LTV-3201 32 in. LCD Television
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
