Question about HP Color LaserJet 2600n Printer
Failed to Print Error
I have an HP 2840 Color Laser Multifunction Printer. It is connected direct via an HP USB Cable to a Dell Latitude D610 Laptop. I have a continous "random" problem of printing a job and the printer sending a "Failed to Print" error. To solve this problem, the only recourse is to turn the printer off and then on.
This usually happens when the printer has not printed something for a few hours. I have the Power Off set at "12 Hours." I have also tried setting the USB to both "high-speed" and also USB at normal speed.
This is very frustruating to have to turn the printer off and on 4-5 times per day. When I check the printer queue, the job is listed but does not print. Only when I reboot the printer will it print. I am running HP Director 45.4.1 software. Any recommendations?
  • kategeorgeco Mar 03, 2009
    i have the same problem. when i try to print from my dell laptop to my hp laserjet 2600n either nothing will happen, or the printer light will print as if something is in queue, but still nothing prints. sometimes i can get it to print by powering off and on, but not always. it is a time consuming pain! help!
  • 47 Answers
Set powermode "allways on" for the lap top. Use an Usb cable no longer then 2 m. Try upgrade firmware for the printer. If still got problem use a powered usb hub between laptop and printer.
Posted on Nov 20, 2008
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
I'm trying to print its says page too complex
A solution might be the proposed in this webpage:
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-Drivers/page-too-complex/td-p/88560
Also, might be a problem with your driver, Download from HP website the latest driver available for your pronter model and intall it.
At this webpage you have the procedure for some other model but it shold be basically the same applied to your model.
HP Color LaserJet 2600n Page Too Complex Errors along with Blank Pages
page too complex
If still can't print, do a Google search for "PAGE TOO COMPLEX" and youll find more comments about issue.
Oct 23, 2015 | HP Color LaserJet 2840 All-in-One -...
Using only HP products color doesn't print
There are two ways to print black (grayscale) only. One is through the printer access provided through HP software. The other is through the Windows printer software. Try accessing through MS, such as printing from office or paint and see what the printer options show. Then try it again through another program, such as PDF Adobe, or another program that brings up the HP printer software. Another option is going through the device/printers option in control panel. Good luck.
Jan 19, 2015 | HP Color LaserJet 2840 All-in-One -...
How we clean the double image of our print?
Need to do a reinstall. Most important is that a page is printed that needs to be scanned into printer as part of setup. Should fixd problem.
Nov 24, 2014 | HP Color LaserJet 2840 All-in-One -...
Dell latitude d630 laptop - os xpp
You are a little confused. The ethernet cable will not fit into the USB socket. Do you mean that it is connected with a USB cable? Is the printer on, with paper loaded and the tray pushed right home? A bit unusual for an HP to jib. Make sure that all cables are well and truly home.
Dec 28, 2013 | HP OfficeJet 6310 All-in-One Printer...
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
My HP 2840 Printer not fully functional via USB with my HP KQ752AA Docking stations (running Windows 7 32 bit), but if connected directly to the laptop it works...what is the problem w/the docking station?
Are you using the same cable to connect? The 2800 series printers do not tolerate USB cables over 10 feet and I have had some that would not connect properly unless a 6 foot cable was used. If you are using the same cable then it is possible that the drivers for the docking station are not installed properly on your laptop and you might need to update them from the manufacturers website.
May 07, 2011 | HP LaserJet 2840 All-In-One Printer
My hp 2840 color laserjet won't print anything
check the connection that may be loose or try to replace data cable
Aug 23, 2010 | HP LaserJet 3390 All-in-One Multifunction...
HP 2840 All in one won't print color
printer is ok, check the connecting cable and drivers.
Oct 28, 2008 | HP LaserJet 2840 All-In-One Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP Color LaserJet 2600n Printer Logo
125 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
