Question about Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V The door of my dvd player will open when button is pushed but closes on its own. Any advice?
  • Anonymous May 02, 2009
    I have difference prolem the door start open when I turn the power on, ethier I push the close button it closed then open again.
  • 10,594 Answers
Its problem of incomplete unloading of CD tray so system control in player sense it and generate command to close it.
CD Loading mechanism needs service and cleaning to loading belt.
If you have electronics experience, you can make it easily. let me know if you need further info.
Posted on Nov 20, 2008
Sony DVP-CX995V Test Mode
Thought I could add a few suggestions for anyone else experiencing this issue.
1.The SLIDER AT THE TOP OF THE REMOTE MUST be in the DVD Position. The sequence will not work if remote slider is in Disc explorer mode or TV mode. It doesn't specify this in the service manual either.
2. Sometimes it just doesn't work the first couple times, so keep trying. For best results, do the sequence from about 5 feet away, pointing the remote at the receiver on the player (lower left), and slowly and firmly press each button, pausing 1/2 to 1 second between each button press works best for me.
3. Also, it could just be low batteries in the remote and If it still doesn't work and it is worth putting more $$ into try a new remote as suggested already.
Just my 2 cents probably worth noting for future visitors to this question.
4. + LINK to FULL FREE Service Manual
SONY DVP CX995V SM Service Manual free download schematics eeprom repair...
NOTE: at the link above Click the Get Manual under the preview to download
Mar 30, 2014 | Sony DVP-CX995V Multi-disc DVD Player
Need Operators Manual for Sony Disc Explorer DVP-CX995V
Sony has documentation for the DVP-CX995V on their support site: http://esupport.sony.com/US/perl/model-home.pl?mdl=DVPCX995V&LOC=3#/manualsTab . The direct link to the manual is http://www.docs.sony.com/release/DVPCX995V.pdf .
I hope this helps.
Dec 05, 2011 | Televison & Video
Can not get dvp-cx995v into hdmi output
Sony has a new firmware release to resolve this issue.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=2824&mdl=DVPCX995V You can download it from this site along with the instructions
Dec 03, 2010 | Sony DVP-CX995V Multi-disc DVD Player
SONY DVD-CX995V "cannot play"
In that symptoms optical block (lens) sounds defective and requires replacement.
Let me know if you want to replace optical block by yourself to provide you more technical info.
Aug 14, 2009 | Sony DVP-CX995V Multi-disc DVD Player
My sony dvp-cx995v
Seems optical lens of unit is causing problem of No Disc.
Clean optical lens with cleaner disc and then try to play dvd.
If still same problem, take unit to local repair shop for fix.
Feb 12, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Hdmi output
There is a firmware update available from sony that appears to address this problem. Go to sony and do a search for the model number dvp-cx995v. I have not tried it myslft but the write seems to address your problem.
May 04, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V will not play through the hdmi output
There is supposed to be a firmware fix for that from sony.
Feb 08, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V Multi-disc DVD Player Logo
162 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
