Question about Sony Playstation 3 (PS3) Console
PS3 going back to normal tv after being on a hd tv.
I connected my ps3 to the downstairs tv which is hd, but when i tried to re-connect it to my my normal tv it doesn't work. I tried it again downstairs to alter it back to the default settings but when itried it on my normal tv again it still doesn't work. It just stays on hd mode. how do i fix this? thanks
  • 1 more comment
  • Anonymous Nov 20, 2008
    same problem
  • Anonymous Dec 03, 2008
    Help! I took my ps3 round to try on a friends tv which is high def then brought it home to use on my normal tv and have no video o/p. I can't take it round to his house again cos he's just flown back out to Afghanistan for 3 months!
  • huggablebum May 02, 2009
    I hooked up my ps3 to an HD tv and had it on the HD settings, then tried to hook it back up to my regular tv because I was only using the HD because I was at my friends house. Is there a way to set it back to regular settings without putting it back on an HD?
Shut down your PS3 then restart by pressing and holding the power button.This will reset your PS3 to its most basic 480p graphics mode so you'll be able to see enough to choose RGB SCART, component, HDMI or whatever from here.
Posted on Dec 28, 2009
  • 36 Answers
When its hooked up to the tv it works on, did you go into the display menu, and switch the settings to A/V mode or whichever your tv is? when you do that the screen on the HD tv will go blank, but then it should show up on the regular tv.
i read this on the playstation site, hope it helps
Posted on Nov 21, 2008
I have an Orion TV and I use a scart lead to connect my ps3 to it , it was all good until I took my ps3 down to my HD TV downstairs where I connected through HDMI and then after I took it back to my Orion...
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Dec 21, 2014 | Video Game Consoles & Games
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I have a ps3 that i tried to hook up to our emmerson tv through an hdmi cable and the tv screen says format not supportedf why?
If you recently moved the PS3 from one tv to another, it's setup to work on that other tv.
Press and hold the power button on the PS3 until you hear a beep. This should default the video output to whatever is plugged in and the PS3 should output normally via the HDMI connection.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
I connected my playstation 3 to another tv and it
If you attached your PS3 to an HDMI capable TV it asks you if you want to switch to HD Mode.
However, once you attach it back to a regular TV you get no picture.
Follow these steps to resolve:
1. Turn off the PS3 so it only shows a red light. You can flick the power switch in the back then back on again.
2. With your PS3 connected to the TV and the TV on, press and hold the power button.
3. Hold the power button until the screen "flickers" and then immediately release.
4. Wait a few seconds and the PS3 logo should appear.
Feb 10, 2010 | Sony Playstation 3 (PS3) Console
Switching our ps3 from hd to normal
with only the PS3 and the TV connected, touch and hold the systems’ power button for more than 5 seconds to switch the system back on. The video output settings will automatically be reset to the standard resolution
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Is the playstation burned out?
Did your cousin ever connect it to an HD tv? If he did, this is a common problem with it. If you operate the PS3 with a normal television set, the ps3 will work fine. But when you connect it to an HD tv and hook up the HDMI cables, the ps3 sets itself to work with HD tv's only. There is a simple fix. a Hard Reset. Call sony customer suuport and tell them that your ps3 doesn't have a menu screen. They will walk you through the steps to restore your system. I would tell what to do myself if I remembered what to do. But regardless, remember this, every time you connect it to an HD tv and want to switch back to a normal tv set, you will have to hard reset the system. Try to remember the sequence the first time so that any other time this happens you'll know what to do.
Best regards,
Gavin93
Aug 18, 2008 | Sony Playstation 3 (PS3) Console
Ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,146 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
