Question about Acer Aspire 3680 Laptop
Operating system not found
Hi, I turned my computer on today, and it says media test failure, operating system not found. Please help
  • haleyraexo7 Dec 02, 2008
    same problem. and it's not working
    New Friend:
  • 33 Answers
It sounds like it could be a corrupt OS, or your hard drive could've decided to pack it in.
Before you panic - (been there/done that). Try to get your system to the boot menu by doing the following:
Turn on your system - once you see the logo, begin to tap the f8 key repeatedly until the boot menu appears. It will give you the option of "Last Known Good Configuration". Select that by using the arrow keys to move the highlight bar up (or down). Press enter - and wait. If there has been a corruption, it may take time.
If that fails, repeat the process and once you get to the menu, select SafeMode. It will probably fail as well but I have seen times when it boots through. If you are able to get into SafeMode, if that works, let me know and we can look at some preventative measures.
Good luck with that
Posted on Nov 21, 2008
Hi my acer aspite 5630 when turned on does not boot up It says ERROR 0701 USB Over Current on HC Port When i pass this point it say media test failure check cable operating system not found ...
some of the physical component inside the cpu has been not fixed properly try to fix by ur self or assist a technician to avoid the error free booting.
Feb 16, 2014 | Computers & Internet
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.The hard drive needs to be replaced in the computer/laptop, Windows installedand the computer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Feb 02, 2012 | Microsoft Computers & Internet
Hi, I am seaman and shortly today I am in New Orleans.Need help for my new Toshiba NB 505,when I try to switch him on got on screen,after minute, "Media test failure,check cable" and on the end...
Sounds like the computer can't detect the hard drive, which means it is most likely bad. If it's a new computer I'd swap it out or return it.
Sep 11, 2011 | Computers & Internet
I GOT THIS MESSAGE TODAY PXE-E61 MEDIA TEST FAILURE CHECK CABLE WHEN I TRIED TO BOOT MY ACER ASPIRE 5630 THIS MORNING. IS THERE A QUICK FIX FOR THIS? EXITING BROADCOM PXE ROM OPERATING SYSTEM NOT FOUND
It is trying to bbot up using network boot because it cannot find OS on the hard drive, you can turn off the network in the BIOS setup page, but more likely you have problem with the hard drive or the OS is corrupted.
Nov 04, 2009 | Acer Aspire 5630 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Acer Aspire 3680 Laptop Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
