Question about Samsung TXG2547 25" TV
Samsung LNT4061fx does not turn on
I have a samsung LNt4061fx and the tv does not turn on. when it is plugged in, it keeps clicking on and off by itself. the screen stays black
  • Anonymous Mar 02, 2009
    mines turns on then off then on again then off again and finally on a 3rd time.
  • Anonymous May 09, 2009
    We are having same problems--started at taking 2 or 3 clicks today it tried for over a half an hour. I hae read online that this is a major problems and it is quite expensive to fix. For a $1400 TV that is only a yar and ahalf old this is very discouraging.
  • 927 Answers
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
  • 3 Answers
I just took mine into the shop for the same problem, very irritating hearing it turn on and off all the time just to start, it would take like 10 minutes for my tv to finally turn on, the technician at the shop said the power supply was bad and i wasn't getting enough power to the main board to turn the TV on, 200 bucks later, I am happy, fix it, it is worth it.
Posted on Apr 24, 2009
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Dec 26, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
I have a samsung model: LN-T4061FX. when turning on the tv, it has a distorted picture, the sound is good. if i smack that **** out of the top of the tv after multiple tries the screen will eventually
flext tab bond is the most likliest cause. They tend to lose their bonds and then usually hitting the top edge of the screen will lock it in. Flex tab issues will make part of the screen take on distortions and slow response of the pictures movements in the screen
Aug 05, 2012 | Samsung Televison & Video
My samsung LNT4061FX/XAA is flashing/blinking
There seems to be a common issue on several Samsung's where picture flickers/blinks. I first started seeing it a few months ago here and in the shop where I work.
Samsung is in some cases repairing it for free--seems the problem is on the power board (scene changes) can trigger it.
Solution in most cases is to REMOVE a jumper plug/or wire on the power board. A design flaw of some kind not anticipated by them.
A call to Samsung will resolve this either by them fixing for free or confirming this is the case---seen about 8 sets here where it did fix the set.
May 30, 2012 | Televison & Video
My my samsung LNT4061FX/XAA turn on but no pictures only sound whats wrong with it
If you shine a flashlight onto the screen, can you see a very faint picture. If yes, then your lcd panel is not lighting up. Replace the inverters or the panel.
first I would check the power supply for faulty caps, replace if neccessary.
Feb 23, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Samsung LNT4061FX/XAA HDTV. It is taking a long time to turn on and its clicking when u push the power button until it finally turns on. I was thinking it is a relay or a switch, possibly the...
Power supply board,have dead capacitors,they bulges up or bust open.U have a soldering iron,solders,solders witchs,u know how to solders?U know basic electronic.Check the power supply board for these defective capacitors replaced these capacitors.Will get ur power back correctly.Or tries websites Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 20, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LNT4061FX makes clicking noise before coming on.
Replace capacitors in power supply you will see that they are bulged on top
Sep 13, 2009 | Televison & Video
I have a Samsung LNT4061FX/XAA Serial no. AHBA3CSPA03617J. The TV will not turn on. It just continues to Click and the Red light in the front goes on and off. Is there a part available to fix this problem?
Regarding the problem with LNT406FX/XAA models not powering up - I contacted Samsung @ 1-800Samsung and they issued a repair tag and put me in touch with a repair company that came out the next day and replaced the capacitors on the power supply. Apparently Samsung got a batch of bad capacitors from a supplier and they know which TVs by the serial numbers. My TV was 28 months old and there was no charge. TV works fine now. Good for Samsung for acknowledging they had bad parts for and getting the tv fixed at no charge.
Aug 17, 2009 | Samsung Televison & Video
Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Dec 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
325 people viewed this question
Jerry Greenberg
Jerry Greenberg
