Question about Fuji Cameras
How do I increase the resolution from 72 dpi to 300 dpi on this camera?
  • 13,433 Answers
You can use a photo editing software on your computer to change the dpi,
dpi has todo with printing and scaning dpi has no real change in the quality of your camera pictures
look at this page
http://www.rideau-info.com/photos/mythdpi.html
Posted on Nov 24, 2008
Can I change 70 dpi to 300 dpi in my canon 60d camera?
You do this in your editor. In photoshop you go Image -> Image Size and you'll see resolution set at 300 as default just change the 300 to 72.
Apr 25, 2016 | Canon Cameras
Dpi issue
reset your camers settings.
Apr 01, 2008 | Fuji FinePix Z1 Digital Camera
My pictures are only 72 DPI. How can I change the resolution to higher quality?
The dots per inch setting (DPI) is meaningful only when printing the picture. As such, the camera simply fills in a default value of 72. You can change it in Photoshop or any other photo editing program. The resolution setting on the camera only changes the number of pixels in the picture, not how you print it.
Feb 16, 2012 | Casio Exilim EX-S12 Digital Camera
Change 72 dpi to 300 dpi
Your camera cannont shoot at either 72 dpi or 300 dpi. It shoots at whatever resolution you have it set for. Dpi (dots per inch) is a print specification, denoting how large (or small) your pictures are printed.
The DSC-W100's highest resolution is 3264x2448. Printed at 72 dpi, it can generate a print bigger than 40x30 inches, albeit a bit grainy. Printed at 300 dpi, you can generate 10x8 inch prints.
Again, dpi is a measure of how you print pictures. It has no bearing on how you capture images with your camera.
Mar 15, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
Want Increase resolution from 72dpi to 200 dpi
increase in dpi will not increase the resolution. dpi = dots per inch for example you have a res of 1024x768 at 72dpi you get a printed image of 14.2x10.6 inch at 300dpi you get a printed image of 3.4x2.5 inch
only thing possible is to interpolate the image. but thats **** in my opinion.
Jul 23, 2009 | Fuji Finepix S5800 Digital Camera
Why does the FinePix E510 pictures download from the camera at 72 dpi when the camera was set to take 500 megapixel photos? I cannot find any way to adjust this in the finepix manual or in online help. I...
A couple of things - I don't think you mean 500 megapixels (that is a lot!) but I assume you mean you expected a high resolution image. You may have it! The dpi setting is largely irrelevant (for photographers) as it simply relates number of pixels to a (notional) print size. Thus an image that is 3000 pixels wide (say) would print out to 10 inches at 300 dpi (3000/300) or 40 inches (approx) at 72 dpi (3000/72). the image has the same information /resolution - it's just "spread" further on the larger print. You can easily change the nominal dpi in e.g. Photshop Elements but it won't affect your image quality.
If however you are getting low resolution images when setting the camera differently that's something different. I would need extra info to help there but pssibly check if the camera was set to RAW and maybe you were looking at the (small) JPEG usually saved with it?
Jun 27, 2009 | Fuji Finepix S5800 Digital Camera
I have a text image in cursive writing. the image size is 72 DPI. I need a way through which i can run this text image & get good 90% to 100% accuracy over transformed text. The problem is whenever i run...
Hello strivastav_p,
It sounds like you are attempting to increase the size of the image. You can do this, but you will always lose resolution. 72 DPI is 72 DPI. It cannot be increased to 300 DPI. Think of it like this:
You have 72 pieces of candy that fit in a small box made to hold 72 pieces of candy, and it looks like you have lots of candy.
Now, you get a big box that can hold 300 pieces of candy and put the same 72 pieces of candy in it. It no longer will look like you have a lot of candy.
Image resolution works the same way. The only way to get the text to be clearer is to scan another copy of it at 300DPI and then do what you need to with it.
Hope this helps!
Jeff
If this response answered your question, please rate it. Thank you!
Mar 12, 2009 | Computers & Internet
How do I increase the dpi on TZ5
Hi - When talking about resolution in digital photography there are two main meanings.
One is the "pixel count resolution" and the other "embedded resolution". So for example your camera could record 2272*1704 as the actual pixel count resolution and set 72 as the embedded resolution that tells other software (for example photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it in your software to 300 for printing. In Photoshop you can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions".
So for your camera the embedded resolution is 180 which you can only change in your PC software.
This is a complex subject, I recommend looking at the following web page:
http://www.fotofinish.com/resources/centers/photo/resolution.htm
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
72 dpi instead of 300
In elements 6 go > Image > Resize > Image size > Resolution change to 300
May 07, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Panasonic DMC-TZ3 72 dpi problem
Sounds like Photoshop's setting, or default setting, is to import picture at its maximum size. If you RESIZE pic on Photoshop, it shoud automatically increase DPI while reducing physical size.
The other thing to be aware, TZ3 defaults to a certain jpg compression. You can minimize compression of data with settings options on TZ3, but I doubt this has anything to do with your PhotoShop issue.
Also, in SIMPLE mode you can select a physical size for photo, even after pic is taken(resize), on camera.
Hopes this helps.
May 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Cameras Logo
391 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
