Question about Intel D865PERL Motherboard
Restart win operating
I have a motherboard d865gl,i replace a hardrive,processor,and memory but my board is still restarts win u start 2 use it....
  • 1 more comment
  • mrmajer Dec 06, 2007
    hi pls check powersupply +5 or replace power supply unit.
    if u thinks software problem go safemode remove driver.
    thanks
    klk_malik
  • Anonymous Apr 02, 2008
    my computer restart when running windows & other prolem is computer starting prolem one more press the start buttion then start computer please resolve my problems
    javed attari
  • Anonymous Nov 10, 2008
    I have around 20 computers witht this motherboard rebooting. I have changed out nearly all compontents and have not found the answer.
    President:
  • 2,961 Answers
Have a look at the bios and see if it loses the time, it may be the cmos battery is flat, and also in the standard cmos settings, enable Halt on all Errors and it may give a clue to the fault.
Posted on Dec 18, 2006
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
Dra.harigopal@gmail.comi'm using DG31pr motherboard with intel core2duo processor,, my pc is not starting when i restarted it... the red led is not turning on after restarting the pc & 3beep sounds...
is a memory problem:
  • Reseat the memory.
  • Make sure that the contacts on the memory and the socket are clean.
  • Try removing one bank of memory modules at a time. (Some systems may require a memory module in Bank 0.)
  • Try using memory modules from the same manufacturer with the same part number and speed.
  • Check for a faulty memory module by trying the memory in a known good system.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 26, 2011 | Intel DG31PR Motherboard
Display problem
remove your processor and the processor fan clean the processor surface with a clean cloth and fix it to the socket apply a thin layer of heat sink compound and fix the heat sink firmly to the processor remove your memory card and clean it with a neat cloth and insert it in the slot and restart the computer still not working remove the memory module and restart your computer you will hear long beeps now insert the memory and restart your computer if you hear only one short beet and display not coming add an pci or agp graphics card if it work the problem is with your graphics section in the motherboard
Nov 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Jul 21, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Restart computer even when bios is open
Check your Processor cooling system.If the cooling is not proper or if the processor is not working properly then the system will restart on its own with in few minutes of boot up process.Also check if there is any infection.
Jul 10, 2009 | Intel Computers & Internet
Restarting PC
your motherboard may be experiencing compatibility issues with that memory youve jst installed. it will work for some time but when it starts to become unstable, it will restart, you have yo adjust the memory timings for that memory in BIOS.
Mar 18, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Msi 478 socket mother board
to: pubudu,
you said that your ram is ok, but i think it's the ram which is your problem because of memory dumping with color blue. yes your ramis ok but the reason why not ok is because the latency is not compatible with your settings in bios
Dec 01, 2007 | Intel Motherboard
Ihad computer pentium 4 mother board asus 845 processor 1.7 my problem that computer open windows normally then making restart again can u solve it
1.) You are infected
2.)One of ur drive wont work propertly
3.)Problem with ur Power Suply
4) Problem with RAM MEMORIE
And use ur WINDOWS XP CD to repair windows
Oct 10, 2007 | Intel Motherboard
D865 Perl with 80 gb sata plus 1024X2 400Mhz DDR Ram
-check your reset button if its not stucked. -else try resetting your CMOS settings to default. -try using your old memory sticks.
Sep 13, 2007 | Intel D865PERL Motherboard
Intel D865PERL Motherboard Logo
55 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
