Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnic dish washer
The dish washer is stuck on a programe how to i re -set
  • Anonymous Mar 20, 2014
    dish washer washes for hours on every setting. Has done this since brand new
My TKD795/3 dish washer makes a nose like the it is sucking water out, but not doing any thing else,(not starting the cycle)
on the door is three buttons with lights on 1 is the "s" shaped symble 1 is a flower like symble and the other the 50 degrea indicator.
what can be wrong, hope you can help?
Posted on Dec 02, 2008
  • jo00738 Dec 03, 2008
    I contacted tecniks help line today, the advice given was that 1 light means out of salt the other out of rinse aid & in order to reset switch off the machines' power, then switch on then hold down the two outer buttons for a few seconds and hay presto hopfully it will work ! I hope so as the dishes are really piling up
Why is my dishwasher is stuck in the drain cycle
What kind of dish washer. It sounds like the switch is stuck try giving the dish washer a through cleaning.
Aug 13, 2014 | Samsung DMT400RHS Builtin Dishwasher
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Hi my classique dish washer won't open,it is full with dishes ,how can i get in.thanks
f your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram attached.God bless you
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Apr 05, 2013 | Dishwashers
Dishwasher does not fill with water
change the water valve on the dish washer.send the model number and i can tell you the part number or if your dryer has it check to see if something is stuck under the float inside the dish washer,if it's stuck up in the air it stops the water from coming into the machine
Feb 18, 2011 | Whirlpool Dishwashers
There is a soapy film on dishes and they are not getting clean, food is stuck on all dishes even after rinsing dishes and running cycle more than once
Change your dish washer detergent ... try something else ... could be a water problem ... but do the simple things first ...
Do you use a rinse aid product?
Nov 24, 2010 | KitchenAid Dishwashers
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Nov 23, 2008 | DISH Network IR Remote Control
MY whirlpool dish washer is stuck on "clean" status and light is juts blibking on and off
See this thread:
http://www.fixya.com/support/t157405-clean_light_dishwasher_stop_flashing
Sep 06, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
The dish washer won't start
press the key with the lock button for 5 seconds. the lock indicator light should then disappear.
Jun 09, 2008 | Kenmore Dishwashers
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
483 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
