Question about Whirlpool LER4634J Electric Dryer
I dropped some screews down where the dryer filter is.
Any idea how to get 'em out without taking the whole darn thing apart?
  • 370 Answers
If you dont have to have the screws, They are ok in the dryer. They either are resting in the bottom of the air duct or have blown out your exhaust vent. They probably blew out. Either way it wont hurt anything. And if you do need the screws you will probably have to buy new ones cause they blew out your exhaust.
Posted on Nov 20, 2008
How do get a small dry sponge out of the Filter shute of my Whirlpool Dryer?
First try a vacuum with a hose or maybe a hanger
Other wize you need to take apart
First UNPLUG FROM WALL
1) 2 screws at top of filter shute
2) take all screws out of back and remove
3) take screws out of back of sute and lift out take out sponge
4)Put all back together
Sep 26, 2014 | Dryers
My kenmore dryer wont start up, makes a humming noise and drum will onlt turn clockwise when trying manully
You likely have a broken belt. A new one should fix you up. If you take it apart to change the belt, please be certain you clean the lint out of every part of the machine. It builds up inside it where you cannot reach without taking the whole thing apart.
Be blessed.
Feb 20, 2014 | Dryers
How to line up screws on back of frigidaire dryer
You gonna need to take the drye apart and put the heater pan back in place. If you try and operate it now you gonna mess up the heater. My heater replacement video shows how:
Here is my page which shows Frigidaire dryer repair videos.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 16, 2012 | Frigidaire GLER331A Electric Dryer
Make very loud rattleing noisewhen on
I had the same problem. No parts were needed
I took it outside set it on my work platform. Took some pix:
I took the whole thing apart and cleaned her up while I was at it
Lube them rollers and work em free.Use zoomspout oil.
Videos and more are HERE
Aug 07, 2011 | Whirlpool Dryers
Dropped a clothes pin down the shoot of the dryer filter vent and now it made a noise when I turned the dryer on, turned it off.
hello. It probably ended up right in the blower wheel. It will make a heckuva racket when things get caught in there. Like a straw in a fan. I will post a few links that will help you recover the problem.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136832&diagram_id=28300066#d28300066 Here is a parts diagram. You can see where things can fall down and land right in the blower wheel.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/take-apart-WP29electricdryer.html This will help you disassemble the dryer and get it out.
hope that helps you. Thanks for your time.
Mike
Aug 01, 2011 | Whirlpool LER5636P Electric Dryer
Dropped item down Dryer lint filter...how to get it out? Tried to go from both ends...no luck...Whirlpool gold..model LER6620PQ0
you will have to take unit apart there are usually screws on bottom holding front panel on unplug dryer first
Aug 19, 2009 | Whirlpool GEQ9800P Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
My dughter dropped an empty gum wrapper into the lint trap slot on an older whirlpool...anyway to get it out without taken aprt the whole darn thing?
the lint filter up top??? if so can oyou hear hte gum wrapper making noises???? if not i wouldnt worry about it, that bent is a direct vent thoughthe blower fan housing and strait outside! id worry if a sock or bra, something of that nature, not a gum wrapper youll be fine
Dec 03, 2008 | Dryers
DRUM WON't TURN on my Roper Dryer
you can put the back back on, remove the 2 screws under the lint filter( if ones mounted to top of machine ), then the top tips back revealing 2 5/16 screws holding the front panel on. lift off hte panel and string new belt arond drum and hook ove rht e motro pulley , first passing the belt through the idler tension pulley. belt number is a 341241
Mar 12, 2008 | Roper RES7646KQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
