Question about Philips Magnavox MS2530C 25" TV
TV turned upside down
I recently moved my 32" Magnavox down two flights of stairs alone. In the process I turned it upside down and even slid it a bit on it's top. Now when I turn it on, it comes on for a second or two with a bad picture (screwy colors) and then the screen goes blank. If you change channels this repeats. Is this a degaussing problem? Will the automatic degausser(sp?)take care of it? Would only an idiot turn a tv on it's head?
    President:
  • 3,130 Answers
Well its not a good Idea to carry a TV set turned upside down because of the heavy parts mounted on the board could cause stress and crack the printed circuit board. This what most likly happened. The PC board is cracked. If you have no soldering skills and do not know how to work on printed circuits or solid state devices, you should seek the help of a pro to assist you in this repair. Good Luck.
Posted on Jan 01, 2007
Magnavox tv screen upside down
Turn the TV upside down...lol....
You can do a factory reset to fix this
Nov 27, 2017 | Magnavox Televison & Video
I have a 60 inch Mitsubishi and there are light red shadows in the tv. is this an easy fix
It sounds like you need to re-adjust your convergence. The purpose of adjusting your convergence is to align your red, green, and blue colors. Moving your TV often causes this problem. I hope you get it going.
Sep 02, 2014 | Mitsubishi WD Televison & Video
Moved dryer, hooked up wrong, not working now after re-hooked up
have you check outlet with a voltmeter or even checked breaker? Is your new rect' a 3 or 4 prong outlet? If you hooked up red's to black and black to reds it still should have worked. The 220 volt heating element is between the red's and blacks the 110 circuits would be between a red or black to white wire.
May 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Color is off shade of red/ pink is on the skin of charaters
Repair solder joints on convergance IC's,but your best bet is just to go ahead and have them replaced.I highly advise that a TV tech preforms the work.
Apr 28, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Toshiba BD-7610 copier moved the copier down a
take the developer unit out carefully shake back and forth free spin the gears by hand clean any spill inside might work in the future remove dv and drum b 4 moving
Apr 09, 2009 | Toshiba Office Equipment & Supplies
I need to move my Proform XP 620 treadmill down a flight of stairs. What is the best way to do this
Honestly, the best way to do this is to call an expert because any wrong adjustments to a treadmill can cause serious damage but if you want to attempt yourself you must try to move it whole with 2 people stronger holding the front of the tread as this is going to be the heaviest. Take the front down first down the stairs.
www.AtlantaFitnessRepair.com
Jan 19, 2009 | Proform XP Weight Loss 620 Treadmill
How to secure front loading drum for moving????
transit bolts vary with machine. pack polystyrene blocks tighty between tub and cabinet and that will do the trick
Sep 25, 2008 | GE WCVH6260F Front Load Washer
Moving the TV
you should be fine as long as you don't drop it of course. you and turn and twist it any which way but id say measure the height of the tv because at some point you will have the top and bottom of the tv touching 2 different walls if im not mistaken
Feb 13, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Can't turn off the CC on my TV
Does your set have menu on front of tv if so press menu use your channel up & down bottons to move up&down menu go to video use your vol up & down to adjust set to off on cc. Also need remote go to Dollar store buy RCA 4 in one remote 5.00 works all tvs has code book with it your code probly 062.
Jan 21, 2008 | Philips Magnavox MS3252S 32" TV
60" HDTV Projection
If it looks like the picture is yellowish all through it, then you will have to have the coolant replaced in all three CRT's. It is not unusual for algae to grow in the resivors.
Mar 14, 2007 | LG RU-52SZ30 52" Rear Projection...
Philips Magnavox MS2530C 25" TV Logo
242 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
