Question about Panasonic PT-53WX42 53" Rear Projection Television
PT-53WX42 53 Blue curve problem
I seem to having the same problem with my 53WX42 set..I see you were able to fix yours. Did you fix it yourself or have a repairman service the tv? If it was serviced, how much did they charge you?
  • Anonymous Nov 27, 2008
    A blue curve line (about 2 ft. wide) is towards the bottom of the screen.
    New Friend:
  • 21 Answers
If you've already replaced the convergence IC's and confirmed the coolants in each tube are filled, you probably need a factory level convergence done.
The procedure is 18 pages long and requires a NTSC pattern generator to do correctly. You need a funtional remote. Personally I'd recommend finding a well-trained tech to do it for you. Takes
about 2 hours to do both 480 and 1080 modes. Anyone who tries to do it from home without equipment is asking for headaches. It's hard enough to do in our shop... (were factory service for Matsushita)
You might get away with a minor touch-up for any particular area, but going into the factory-level setup mode without knowing what you're doing is not recommended - you may find yourself replacing the EEPROM.
Good luck, Mark
Posted on Nov 28, 2008
Having green and pink lines on the bottom and curving in the middle of the tv. What do you suggest for the fix?
It sounds like your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 26, 2011 | Panasonic PT-51HX42 51" Rear Projection...
I have a 50" projetion toshbia the blue will not line up on the bottem there is also a curve i would like to know if it is worth fixing or can it be fixed and can i do this by myself and what part i could...
Hello: Seems your convergence IC's have failed. These are two large IC on the Main Powersupply board. Have both replaced as a preventive measure.
If you are good at unsoldering and soldering componet IC's then yes you can do this yourself.
The IC are STK-392-110 but use 120's instead.
Oct 20, 2009 | Televison & Video
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 06, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Red and Green Spots
Not a fix for do-it-yourselfers, but check with Panasonic as there is a new fix. Requires tech to come and reprogram the eprom (I think).
Cheaper than a new optic board.
Jan 03, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX53 blue convergence PROBLEM
Sounds like you have a blue foldover in the convergence. Since tv has been worked on it could be bad ic, maybe not original, generic. I would say if you can open set and look in, look for the blue it should be marked. look for a loose connection. If you can have someone to gently tap around that blue amp and see if it moves are go away, it might be a simple loose connection and needs soldering. If not then my have to change ic again. Becareful cause set would need to be on to really check. Hope this helps.
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Panasonic PT-53WX42 53" Rear Projection Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
