Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
The brushes won't turn.
My agility steam vac has only been used twice. the square hole doesn't rotate the brushes. i don't know if the on/off switch for the brushes is bad or the mechanism to turn the brushes is defective.
earnest from oklahoma
  • Tim Simmons Nov 26, 2008
    I took the turbine apart and found no problem. Do the brushes turn all the time? What air flow turns the turbine? Does the blower motor behind the turbine create vacuum and turn the turbine? ? I don't believe my turbine is turning at all. Any help is appreciated Tim
  • Anonymous May 21, 2009
    The machine will not turn on......
    Scholar:
  • 55 Answers
There are two reason why the "Turbine" will not rotate. A: It is an air driven device, so if there is not enough air flow through it, it will not rotate. I beleive there is a lint screen on the bottom of the unit that slides down and can be cleaned out. Make sure the recovery tank lid is on properly and there are no missing gaskets in the airflow path. B: The turbine is locked up. This happens a lot. You should be able to rotate the brushes on the block by hand will they are locked into the machine easily(this will manually rotate the turbine. If you can't then your turbine is locked up. What you do then is romove the hood. Screws hold it down in the front and it pops into place in the back. Take out the turbine. There are two screws on the top and two accessed from the bottom of the unit. There are a four screws and a few locks that hold the turbine together. Take it apart, but be careful as to how the gears and washers are arranged and not to lose any small parts. You can usually free it up by hand by rotating the fan on the opposite of the gear box. Once it is freed you can apply a lubricant to prevent it from happening again. I use spray lithium grease. There usually isn't enough lubricant applied in on the gears at the factory, so once you do this, you shouldn't have this problem again. When you first run the machine again it might blow a little excess grease out of the exhause, so to be safe don't fire it up on the carpet, when you first test it. The gearbox may need to be replaced if it is damaged and not just locked up, but this rarely happed. Also, try not to lean the machine all the way back(place the handle on a chair or something) over time it tends to tear the hose inside of it.
Good Luck
Posted on Nov 21, 2008
Steam Vac Ultra five rotating brushes won't ****
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP.
1. TAKE LID OFF OF DWT
2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY)
3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO.
4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN.
5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN.
IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4.
IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC **** UP THE WATER AGAIN.
Dec 18, 2012 | Vacuums
How do we get at the drive belt? The cover seems to be sealed.
There is no belt in a Hoover SteamVac. The brushes are turned by an air driven turbine. If the brushes are not turning, it is usually because the turbine has seized up and may need replacement. Insert a screwdriver into the square hole that the pin on the brush assembly normally fits into and see if it turns. If it doesn't, you will need a new turbine.
Jun 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The Hoover steam vac dual v does not spin its brushes and I dont know how to dismantel it to view the belt .
There is no belt on the steam vac - it operates on air flow. Remove the brush and insert a flat screwdriver into the square hole. If it does not turn, the turbine has seized up and must be replaced. Remember that the brush will not turn unless the lower tank is in place, and the handle is tilted back.
Jan 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Is my 6215-900 brushes drive driven by a belt? I
No, there isn't a drive belt on the Hoover Steam Vac models.
Oct 24, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
I have a hoover steam vac dual v. The brushes will not rotate
The brushe holder is not snapped in correctly. You have to push it in hard.
Aug 20, 2009 | Hoover F6213-900 SteamVac Agility...
Brushes won't turn
this would be a bad turbine and is fairly simple to replace. first take all the screws from the base of your steam vac. then look toward the top under the dirty water tank there will be a black tube with 4 screws that also need to be removed. i believe after this you should be able to remove the hood assy. if not there may be one more screw on the hood, if so remove. at this point you should see the bad part.take 2 more screws and hoses from it and install the good part. hope this helps, this machine is fairly new to me also.
Sep 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover steam vac model 7210-900
Did you clean both filters? There is one on the tank and the other is from the bottom, it ha a red frame, pull it out to clean. Pull the brush block out, is the shaft that goes up into the machine broken off? If so replace the brush block. While it is out, trn the machine on and see if the square hole up where the brush block goes, is turning. If not then the turbine has gone bad. You can sometimes clean the turbine out, otherwise replacing it may be the best option.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes do not rotate on Hoover steam-vac upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
Generic problem for all Vacuums
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
There is no belt, sounds like the turbine is bad and will have to replaced.
Nov 27, 2006 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
209 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
