Question about Canon MF8180C Color Laser MFC Printer
Canon imagerunner 2270 staples on the right side
The copier staples copy packages on the right side of the paper instead of the left. I think it is probably just a setting problem, but I don't have access to the manual, so PLEASE HELP
  • 1,219 Answers
Under user screen you have in lower left corner finisher or similar. press it, and chose staple and left or right
Posted on Mar 02, 2010
My Cannon ImageRUNNER 2270 is not printing the entire page. It is cutting off the top quarter of the page. I have changed the margin settings and it is not doing anything different.
Check to make sure that the paper size dial on the paper cassette is the same as the paper size in the cassette. Portrait or landscape? I don't know whether you use American sized paper but the dial Must be LTR ( front to rear orientation of paper ) or LTR-R ( Left to right orientation ). I know of no other reason for the problem.
Jun 19, 2011 | Canon imageRUNNER 2270 Copier
In 5020i while using the ADF papers are geting folding at right corner only in orginal not in the copy
There may be a staple, paper clip or other obstruction in the paper path. Get a flashlight and look carefully at the left side - top and bottom of the ADF. I've also had problems with the guide located to the left of the glass being damaged and catching the edge of the paper in the curved part.
Jan 27, 2011 | Canon imageRUNNER 5020 Copier
Our Canon imageRUNNER 2270 is copy/printing sidways instead of normal. what happened?
I would look to make sure the paper tray's are set correctly in the paper trays... There is a knob that moves at will.... just kidding... Make sure that when you press on the diplay for paper size's, that if it shows LTR make sure the paper is in the tray going the short way.. LTR or you may have the paper tray set for LTR-R and you have the paper in the tray as LTR. I believe that the paper trays are set wrong. You may have figured it out already.. Good Luck
Nov 29, 2010 | Canon imageRUNNER 2270 Copier
Our Canon imageRUNNER 2270 is incorrectly orienting the paper. How do we fix it?
You can turn off the Auto Orientation of the machine. Go to Additional Functions > Copy Settings > Auto Orientation > On/Off
Oct 27, 2010 | Canon imageRUNNER 2270 Copier
Need instructions to load staples in Canon imagerunner 2270
pull the finisher out
you will see the staple in the end of it
pull up the staple cartridge using the green handle
then insert the new one
Apr 06, 2010 | Canon imageRUNNER 2270 Copier
How do i refill staples in the the canon imageRUNNER 3300?
Look in the Reference Guide. This should come with your copier if you bought it new. Do you have Finisher J1 (internal finisher, paper comes out above paper trays) or the SaddleFinisher and inner2way tray (paper comes out on left hand side of machine).
For finisher J1 look starting on page 7-38. Saddle Finisher 7-61.
Can get Reference and Copy guides here: http://ww2.canon.it/supporto/manuali_operatore/elenco.asp?t=&i=IR3300&id=IR3300
The English versions (which I use, I don't speak Italian) are the ones with ENG in the name.
Jul 21, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ImageRunner 2270 copier - how can I change the paper select
There is a blue papersize sellector in the paper cassette with an arrow on it,just move that sellector untill the 11/17 mark.change the paper stops inside the tray to the correct possition and the machine will display the correct paper size option.
Jun 18, 2009 | Canon imageRUNNER 2270 Copier
Changing staples
It should be in a door below your control panel. If you have a finisher on the left hand side (not pictured in profile) you may need to open a front cover door. There should be a visible handle depression for this.
Aug 22, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Staples
PLEASE PULL OUT HOLE FINISHER AND THEN CHECK ON RIGHT SIDE OF FINISHER JUST PULL OUT CARTIDGE AND INSTALL NEW ONE
Apr 02, 2008 | Canon imageRUNNER 2270 Copier
Canon MF8180C Color Laser MFC Printer Logo
65 people viewed this question
old marine
old marine
