Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Dryer is making a loud squeeling noise when running
It is a loud squeeling noise
  • Anonymous Dec 22, 2008
    Dryer makes a constant squealing noise. I removed the belt, and when I turn the motor by hand, there is a dragging noise toward the front of the motor.
  • jeanette789 May 08, 2009
    I have a similiar problem, the dryer jammed when the sweater dryer insert was dislodged, I replaced the belt, but it still won't stay in the groove and it doesn't seem tight.
    President:
  • 842 Answers
This is probably the drive belt slipping on the drum or motor. There is usually no adjustment on these and it is a case of replacing the belt. If you take the top off the machine, you may be able to look inside while it is running (KEEP CLEAR OF THE ELECTRICS AND DO NOT DELVE INSIDE WHILE THE MACHINE IS IN THIS STATE!) and see the belt slipping. If it is, it's probably time for a new belt
Posted on Mar 13, 2009
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
Maks loud squeeling noise when first turned on then quiets down after a few minutes of running
drum rollers/glides, belt is wearing or idler arm is wearing:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 04, 2011 | Frigidaire FGR231A Gas Dryer
Dryer makes loud squeeling noises when running.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 02, 2011 | Dryers
Loud squeeling noise. Sounds like a bearing.
heatman101
Asker
Nov 20, 2010 | LG DLG5988 Gas Dryer
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag Dryers
Squeeling while drying
worn belt, needs replacing
Oct 07, 2009 | Dryers
I have a Maytag dryer that was in storage for 2 years. It works fine but it makes a big noise when it starts and ends.
Describe the noise. Does it sound like someone hitting a drum or a loud squeel or a big snap? Is it a short noise or does it make the noise and fades to nothing?
Also, what's the model number.
Thanks!
Jul 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Very Loud Dryer
squeeling hi pitch is usually the drum support roller above the heater. if you take the machine apart and turn all moving parts by hand you should be able to find the problem...if its a rumbling noise then it may be the blower wheel. UNPLUG FIRST..good luck :)
Jun 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
225 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
