Question about ParkerVision SIGNALMAX WR1500 (884181000031) Router
LOST SOFTWARE TO PARKERVISION WR 1500 --- PLEASE HELP ! ! !
I have a parkervision wr 1500 router and cannot locate the installation disk and NEED to connect it to my wireless network......
    Problem Solver:
  • 13 Answers
Posted on Mar 16, 2009
You do not need to have a disk for the router. The router has firmware built into the router. Make sure you have your lan into the 1 port and type in your browser 192.168.150.1 and it should take you to a screen to log in. The default is 1234 for the user and password.
You should be able to use the wizard inside of the router after you log in. Hope this helps!
Posted on Mar 14, 2009
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
My promblem is that I already have a wr 1500 wireless parkervision but i cant fine my power supply .so my question to you is what power supply do i use? I have the manual but it show you what adapter to...
You could try asking them at:- support@parkervision.com
or, look closely at the router, a label probably underneath, for the voltage the box uses.
Probably 6v,9v or 12v then buy a universal ac adaptor which gives you the required voltage and the correct DC input plug to your device.
Ebay or more or less any electrical shop, if going to a shop, take the router with you, easier to check out the DC in plug.
Jan 02, 2011 | Computers & Internet
Where do we locate the encryption key info for our router so we can install a printer?
Here are the two manuals concerning yoru router.
Quickstart guide
Users Manual
Page 20 shows you the location of the WEP key and the previous few pages explain how to get to the key.
If this helped you then please help me and vote kindly, thank you.
Oct 15, 2009 | ParkerVision SIGNALMAX WR1500...
How can I get and install the latest firmware update ParkerVision Routers?
  • goto the website of your router brand, or search on the google.com
Aug 11, 2009 | ParkerVision SIGNALMAX WR1500...
New internet provider and now can not use remote viewing
If you have changed Internet Providers (which I assume you have considering you refer to changing from DSL to Cable modem), your "location" on the Internet has also changed.
Try going through the setup process with your Slingbox again as if it were the first time you had installed it.
Mar 18, 2009 | ParkerVision SignalMAX WR1500 / SignalMAX...
ParkerVision Signalmax WR1500
from the original docs:
Reset Button
The WR1500 Wireless Router reset button is built into the rear panel. Use this button to restore the factory default password to 1234; IP address to 192.168.1.1, subnet mask to 255.255.255.0 and DHCP sever enabled with a pool of 8 IP addresses starting at 192.168.1.33.
note my unit resets to ip 192.168.150.1
Sep 29, 2008 | ParkerVision SIGNALMAX WR1500...
My new alarm system / wireless router
What type of Alarm system? If that pakervision has network ports on the back there is no reason they couldn't run a cable to it and setup the security for you. I've never heard an alarm company tell a consumer "No you can't have wireless in your house" I'd need to know the model # of that parkervision because this doesn't make sense to me. If that parkervision doesn't have any network ports on it... yea go out and buy a wireless router that has ports on it.
May 01, 2008 | ParkerVision SIGNALMAX WR1500...
Parkervision wr 1500 ip address
congaman:
You have to connect that 'access point to your machine directly' check for the ip address as the default gateway, assign your machine an static IP from the same subnet, hit refresh in the IE and you should see the log on page of that 'own made access point'.
If the network connections give you sign of exclamation hit repair.
or
THe best option is to refresh to factory defaults, and then start settings as you like to in this access point. Hiding a network is no trouble at all, once you are inside the access point you can reset your security settings as well. So the best option will be to reset the access node.
Hope it helped!
Thanks
Dec 10, 2007 | ParkerVision SIGNALMAX WR1500...
ParkerVision SIGNALMAX WR1500 (884181000031) Router Logo
675 people viewed this question
Top ParkerVision Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Percy Silwane
Level 1 Expert
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
