Question about HP LaserJet 1020 Printer
PRINTING PROBLEM MY PRINTER IN PRINTIN DOUBLE IMPRESSION ON FRONT PAGE OF TEXT ABD PICTURES
Change the cartage pcr roller
Posted on Jun 07, 2007
  • 62 Answers
Replace the toner cartridge
Posted on Apr 22, 2007
Very bed image on a paper
Print a couple of pages. As the printer is printing open the toner cover. Pull the toner cartridge out and look down at the paper. If the printing looks good the fuser probably needs replacing. Before doing that, have you checked the toner cartridge.
Mar 09, 2014 | HP LaserJet 3015 All-In-One Printer
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
How can I do double-sided printing with my Canon MP460?
Hi there!You printer does not have an automatic duplex(double-sided printing)so you have to make a manual double-sided printing.When you start to print something , in the widow of the printer click on the preferences and look for the option "Print on both sides" or "Manual double-sided printing".When you start the printing the printer will print page page 1,3,5,7..... on the one side of the paper.After the printer finish you have to take the papers and put them back in the printer with the other side of the paper.Then the printer will start print page2,4,6,8,.....If you need any other help please replay!Tghaky for using Fixya!!
Dec 18, 2010 | Canon PIXMA MP460 All-In-One InkJet...
When photocopying, leftside print missing/text
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve....
before that pls. check your cartridge unit...
Apr 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Printing is blobby rather than sharp
That my friend is your cartriges,i had the same problem.
Sep 28, 2009 | HP Photosmart D7360 All-In-One InkJet...
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Problems printing a booklet
What size paper are you printing on? Reset the side margin to make narrow and see if that helps.
Sep 23, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
HP Laserjet 3550
double check ALL the print settings (i.e. paper type, document type, etc). Depending on which option it is even one "box" or "setting" being changed can alter your printers function. Try looking for options that will auto detect the type of document you are printing (ie, color, with pic, plain, etc).
Jun 12, 2008 | HP DeskJet 3550 InkJet Printer
My printer makes lines through all the pictures i try to print
I had same prob with Epson but went into preferences/main and changed from text and graphics clicked to picture or best picture..problem solved.
Aug 26, 2006 | Canon PIXMA MP130 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
