Kenmore Elite Oasis HE/ Error Code F1
Upon Starting the washer it locks the door and starts, then The F1 Starts flashing and the washer stops. IF I stop it and start it really quick by the third try It will run through it's cycle. Help this has been an ongoing problem since I bought this machine. I am really frustrated with this. When my washer was about 18 months old, it started flashing the F1 code at the beginning of the wash cycle. I have to push stop and start four times then it works until it gets to the rinse cycle. Then it flashes F1 again. At that time I push stop and start two times and then it works. So far I have been doing this for months. I have called Sears and they want to send a repairman out at the cost of $65.00 just for the call. I am not letting them come because I have seen what it costs to fix this problem. I have read where others have spent between $300 and $400 to fix it then it won't stay fixed. I will use it until it tears up completely and then go buy me a cheap machine that will probably do a much better job.
  • 370 Answers
Sorry to tell you but you have a faulty control board. It is a bad part from the factory. They know that its bad too! They have completely remanufactured the part. There is lawsuit against whirlpool (whirlpool made the oasis) for the problem. Some people have been able to call and complain to whirlpool and got them to pay for the repair. Complain a lot. Good luck. sorry for the bad news.
Posted on Nov 20, 2008
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Oasis He 27082603
Folks F1 means the board is bad, I would definitely call the line listed above with model and serial number. They will schedule a tech, maybe me if your in Phoenix and they will give you a receipt, but if there smart the call will be set to transfer the charge to Sears:)
Posted on Oct 11, 2008
SOURCE: Kenmore Elite Oasis purchased from Sears 8/07
Can not open the top the cover is locked is there a reset button.
Posted on Nov 29, 2009
  • 3 Answers
SOURCE: F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Posted on Feb 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: F1 code sears Kenmore and Whirl Pool ( who make
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Posted on Sep 18, 2010
TheMobilian
  • 8220 Answers
SOURCE: my sears oasis washer reads f1 code
That F-1 code may be related to a failed pressure sensing due to a pinhole leak or a tubing fell off or sediment in them bottom of the tub. Check that tubing to see if it is blocked with stuff that may impede the control from correctly sensing the water level. use them lungs to blow out any sediment you might have in there and reconnect that tubing securely to that control. It don't cost nothing to do these things before ordering any parts. If you done fixed it then party on my friend. I have more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 15, 2011
My kenmore oasis shows the f1 upon starting the machine and at 23 minutes and often shows th ul why is this
Mine is doing the same exact thing. Just after I press "Start", the F1 starts beeping. Then at 23 minutes into the cycle, it does it again. So frustrating! What is wrong with this machine?
May 20, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 code coming up on my Oasis HE washer
YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Ok these are not the series 70, getting a model number off the door will reallllllly help. Some of these sound like the oasis. F1 is motor control or primary control failure and F 41 is a rps thermistor failure.
For the guest with the 11027086601 kenmore elite oasis here is a link for supplying me with a partial model number, much thank yous!! paste in a browser:)
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11027086601&productCategoryId=0153200&brandId=0583&modelName=RESIDENTIAL WASHER&diagramPageId=00002&componentDescription=CONTROL PANEL PARTS&documentId=K0601003&backToLink=Return to Sub Components list
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
446 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
