Question about HP Computers & Internet
HP Laser Jet 3055 "Yellow" flashing exclamation point and ready button NO PRINT CARTRIDGE Replaced cartridge same message appears NO PRINT CARTRIDGE Have tried repositioning plus numerous off and ons....
    Sergeant:
    Champion:
  • 334 Answers
Try using q tip and cleaning the connections on the cartridge and the printer with alchol and see if that helps. Also see in your owners manual if there is a reset that you need to perform.
God Bless Greg
Posted on Nov 20, 2008
Hp laserjet 3055 printer print blank pages how solve it`
1) Check the toner cartridge: Is it new? Is any protective tape or cover to be removed actually removed before installation? Is there any other obstruction preventing the toner from coming out?
2) Check with the printer itself: the drum to pick up the toner may not be charged each time.
Sep 07, 2014 | HP LaserJet 3055 All-In-One Printer
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Replaced the yellow ink cartridge with a new one and message still appears on screen that the yellow cartridge needs replacing. Appears that the printer does not "see" this new cartridge. I...
This sounds like the chip on the cartridge is defective. Try a different cartridridge. Take the failing cartridge back to the vendor for a replacement or refund.
Your description for corrective actions taken are in-line with accepted procedures.
Let me know if you have any other questions. Thanks.
Jan 18, 2011 | HP Officejet 6500 Wireless All-in-One...
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
