Question about Refrigerators
How do I stop defrost on Hotpoint Fridge/freezer?
There is a button to push to start it but now I want to finish it. Unplugged for a few minutes and plugged it again, but the freezer still isn't cold. It's Hotpoint Iced Diamond R134A.
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.? takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
SOURCE: red and green light on
your filter needs to be changed when it is red
Posted on Apr 17, 2008
SOURCE: Hotpoint iced diamond fridge freezer red light
Buy a new fridge
Posted on Sep 22, 2008
  • 410 Answers
SOURCE: Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Posted on Jan 29, 2009
  • 159 Answers
SOURCE: hotpoint iced diamond fridge just stopped working
firstly change the thermostat
Posted on May 15, 2009
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
I have a hotpoint fridge bottom freezer and after I had filled the freezer with my shopping yesterday, it started making a shreeking noise, I thought maybe it needed defrosting, which it did, so I...
If both section are not working as required then its compressor fault.The noise you noticed must be from compressor related parts,that are fan,the motor and relay.But If freezer is getting over cold and friezed and fridge section not getting cold then Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Hotpoint FFA45 Bottom Freezer Refrigerator
I have frost free hotpoint future,the fridge seems to be working but the freezer isnt at the minute, the food is not freezing and the fan does not seem to be working! it has no suction on doors either, my...
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 15, 2010 | Refrigerators
Freezer vents are building up ice.
I believe it is time to change the defrost timer and check the remaining major parts of the defrost system. I will give you a page to go to where you can view theses parts and enlarge them to help you see what we need to start with. (defrost timer). Part WR9X502 Defrost Thermostat part WR50X10025 and the defrost heater WR51X10038 Now this is parts for the model listed above your post right? BRB, Sea Breeze
Jan 06, 2010 | GE Hotpoint® HTS18BCPL Top Freezer...
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Jun 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
I have a hotpoint ff93p fridge freezer and the fridge is running at plus 23 the repairer has charged me 95 pounds to change the two small wired parts (temperture controls) in the freezer and has not solved...
You may have a defrost problem. It could be either the defrost control itself or the defrost heater. You would have to look at your evaporator coil to see, if it is frozen solid. If the evaporator fan working? It should stop, when the freezer is in defrost. If it never starts, either the fan is broken or your defrost control is stuck.
May 17, 2008 | Hotpoint Refrigerators
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Refrigerators Logo
210 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
