Question about Mitsubishi VS-60719 60" Rear Projection Television
Mits VS-6071 Repairman removed a part and left never came back
My tv picture went out, still had sound. repairman removed a circuit board, left, never came back. the board is approximately 4 1/2 inches by 3 inches, has a silver protective cover over part of the board. imprinted on the silver cover is; VR7001, VR7002, LC7101, LC7102, on the reverse of the board, on a metal protective cover is the following TR-RC, TR-WC, GND, GND. could someone explain what this is and it's function, then remedies? thanks in advance. i tried to turn on the tv, it sounds like this, click-click, that's it.
    Problem Solver:
  • 12 Answers
It might be the digital tuner board, or an audio board did it come from the front or rear of the TV can you post a pic of it?
Posted on Feb 03, 2007
PN59D550C1FXZA 59in Plasma picture comes and goes
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Check the Va and Vs voltages. These voltages should be so accurate as marked on the silk screen behind the display panel. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 28, 2016 | Televison & Video
The tv works but without picture
YOU HAVE A INTERNAL TV PROBLEM ON A ELECTRICAL CIRCUIT BOARD. SOUND WILL COME THRU BUT NO PICTURE. IT WILL NEED TO BE SERVICED BY A TV REPAIRMAN. ON CERTAIN TVS IT MAY BE AS SIMPLE AS A CONNECTION CABLE FROM THE CIRCUIT BOARD TO THE TV SCREEN, BUT IT IS STILL A TV SERVICE REPAIR FIX. - SORRY
Feb 20, 2011 | Home
Chirps when powered up
i have a 42 in magnavox lcd tv and it wont turn on at all and is also making a chirping sound coming from the back left of the tv. Picture just went out and gave a bad smell.
Oct 05, 2009 | Philips Televison & Video
Projection TV, Sound but no Picture
If this Tv is a model year 1996 or 1998, It is quite possible your vertical IC needs resoldered. It is located on the small signal board. This board [quite large anyway] is the board on the left. I don't know the location off hand. The IC has seven pins and located on a heatsink, It is a TDA series. Resolder any and all grounds you see. May as well get the Large Signal board [On the right] resoldered. The other problem would be the P I P board, a small board standing up, that can be removed and replaced. But try the earlier first. This is tedious, but will produce results.
Jul 12, 2009 | Mitsubishi VS-5059 50" Rear Projection...
Need DM or FMT PC board
If the front light of the TV is blinking green suspect caps are bad and change them yourself, google for cap locations
Nov 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
VS-45607
YOU HAVE THE DREEDED CAPACITORS GOING OUT...AFTER A FEW YEARS-THE CAPS LOOSE THERE PURPOSE AND DEPENDING ON WHAT CIRCUIT THERE IN --YOU WILL SEE THE ASSOCIATED PROBLEM,,,EXAMPLE--COULD BE SOUND ,PICTURE (YOURS) OR VERTICAL(PICTURE CLOSING UP) ETC... YOU CAN HAVE CHECKED BY A REPAIRMAN BUUUUT ,MAY NOT BE COST EFFECTIVE ,,TUNICA
Oct 24, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60609 60 in. I get sound but no picture. Just a red, green and blue lines in the middle of screen. Looks like a hour glass shape.
That sounds like a bad vertical circuit. Do you know how to use a meter and solder? If so we can troubleshoot otherwise you will need to call a repairman. A good repairman should run you $300-$500 to repair this. Let me know what you would like to do!
TIm Nolan
Sep 24, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi Vs-6071 Picture
replace the signal board (one with all the rca's on it) and not the main board if a plain antenna works OK
Jun 05, 2007 | Mitsubishi VS-60719 60" Rear Projection...
How to fix the video power supply for mit VS-4544 ?
Let me preface what I'm about to suggest with my own comments. I've been a TV Technician for more than 20 years. That said, you don't fix it without calling repairman or you wouldn't have posted here. In this unit there are common lytic caps that should be replaced without question. By location number and value they are: C979 2.2uf/200v C531 2.2uf/160v C551 2.2uf/160v C981 22uf/50v C402 47uf/35v Next it might be a good idea to ESR test other caps in the B+ line. ESR stands for (equivalent series resistance) It's a way of measuring the cap's effectiveness in a circuit. There are testers on the market for just under $200.00 for the backyard technician and they are a must. Check the set for ring cracked solder joints. The symptom of leaving it off for awhile and then being able to get a picture suggests that it could be ring cracked in one or more areas, usually areas of high heat. When all else fails there is calling the repairman. If you don't know how to find a reputable shop in your area I might suggest contacting NESDA (National Electronic Service Dealers Assn.) who can give you some reputable shop contacts in your area. Good Luck! Bill
Jun 02, 2007 | Mitsubishi VS-55705 55" Rear Projection...
TV not turning on
Four bad capacitors in DM module = common repair for a
qualified Mits repairman.....1000mf/25v 105 degree............T.
Jan 18, 2007 | Mitsubishi WS-65713 65" Rear Projection...
Mitsubishi VS-60719 60" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
