Gateway 400SD4 Notebook Logo
Anonymous Posted on May 08, 2012
Monitor does not light up at all.
All the power up led's on the top of the keyboard face do not funtion either . This happens after my two year old daught pushed several keyboard buttons.
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on May 09, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1060740
Points
15385
Did she spill something on it? Have you tried to make sure it's not an issue with your bright and dark buttons or keys on the keyboard?
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
1 Related Answer
Anonymous
  • 121 Answers
  • Posted on Oct 10, 2009
SOURCE: MX6448 won't boot; black screen.
It seems that you don't remove the battery when you use the Notebook. This practice shortens the life of the battery because, when you use the a/c adapter and the battery, your battery is alternately charging and discharging all the time. The cells in the battery eventually die.
From what you describe, it sounds like the power strip inside the Notebook (where you plug in the adapter cord) has been damaged and needs to be replaced.
Your computer is not a total loss. Just have that power strip and the battery replaced and your Notebook should be up and running again.
And, in the future, if you just remove the battery when your kid uses the computer, or if you are going to be using it for over 1 hour. Save the battery to use when you need the mobility.
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: https://how-to-repair.org/repair/lg-tv-repair-manual-pdf/lg-led-tv-no-backlights-32ln5300-32ln5310-32ln5700-voltage-test-troub/2pyuXwNkBMA.html and follow the steps how to repair back light LEDs: https://www.youtube.com/watch?v=_poWTEihIJU Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-3-0.jpg
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
On my asus Eee Pc 1201HAB the display shifted to the left so the left side is partially cut off, how do i fix it?
1) Looking at the User Manual right now, and do not see a Hot Key on the Keyboard, that shifts the display.
[ Hot Key is also known as Special Key. The F1 through F12 keys at the top of the keyboard, and also for your model, colored keys on the keyboard ]
It could be the Screen Resolution is messed up. Not set at the correct settings.
Right-click on an empty area of your desktop screen.
At the bottom of the drop down list, click on Properties.
In the Display Properties window click on the Settings tab.
The screen pixel resolution should be set at 1366 X 768,
http://www.screentekinc.com/Asus_EEE_PC_1201HAB--12.1-inch--1366x768-wxga_hd-laptop-lcd-screen.shtml
In the middle of the Display Properties window, you see the blue subheading - Screen resolution
Right under this small subheading is a Slider.
The Pointed 'arrow' with the green tip, and top, slides back, and forth on the 'line'.
It should state 1366 X 768.
If it does not;
A) Left-click on that green tipped Slider. Hold the left mouse button down. Move your mouse, and move the Slider. (Drag)
Move it to the Left to Decrease the screen resolution, or to the Right to Increase the screen resolution.
Can't set it to 1366 X 768? Post back in a Comment.
ALSO, the Color Quality should be set to -
Highest (32 bit)
If not click on the blue down arrow to the right of this box.
In the list left-click on Highest (32 bit)
Now go below to the right, and click on Apply.
After go below to the Left, and click on OK.
Still no joy?
Believe the problem is hardware related.
Could be something as simple (?) as a bad Video Cable.
(Goes from the motherboard, up under the left Hinge, and then up into the Display Assembly)
Could be the screen Inverter.
However the Eee PC 1201HAB is supposed to use an LCD panel, that has qa series of LED's for backlighting.
Newer backlighting that uses a series of LED's for the Backlight, doesn't require a screen Inverter.
There were some LED backlit LCD screen, that DID use a screen Inverter. Mostly the older models of laptops.
This is what makes me think your LCD screen's Backlight, (And LED), may use a screen Inverter,
http://www.batterystyle.com/asus-eee-pc-1201hab-screen-p-168219.html
Scroll down,
"5. Disconnect the power cable and video cable from the Asus EEE PC 1201HAB Lcd panel. The power cable connects the screen's power source, the lcd inverter, to the backlight lamp attached to a side of the panel."
Probably just a generic form, and didn't take in consideration that the Eee PC 1201HAB netbook, uses a series of LED's, as a Backlight.
May not have a screen Inverter.
To explain;
Primer:
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
(Click on the window with the computer monitor in it )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
[ LED = Light Emitting Diode.
CCFL stands for Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
{Average thickness of a CCFL bulb is 2mm. That is a a little larger than 1/16th of an Inch.
The average length is almost as long, as the LCD screen is in height]
A screen Inverter is used to CONVERT the power from the laptop, for the LCD screen, and Backlight.
Do not see any listings for an Asus Eee PC 1201HAB netbook, for a screen Inverter. Believe the LCD screen uses LED's for a Backlight, and does NOT use a screen Inverter.
Which means if the problem is in the Display Assembly, the LCD screen itself will need to be replaced.
The LED backlighting is built-in.
[Hmmmm, I see a trend going on here that I do not care for, and just woke up to it. Have to replace the entire LCD screen, and cannot just replace the Backlight, or screen Inverter? Sounds like Ka-ching $$$$$ for somebody!
A screen Inverter usually averages from $20 to $40+.
A Backlight ( CCFL) usually ranges from $10 to $15.
An average LCD screen can range from $80 to $300+.]
How to know if the problem is in the Display Assembly?
Use a VGA monitor, and connect it to your laptop.
A) Laptop OFF, monitor OFF. Connect a VGA monitor's cable to the VGA port on the laptop.
(Left side rear. This is an example of a VGA Cable, and VGA connector { Port on a computer },
http://en.wikipedia.org/wiki/VGA_connector )
You can use an older CRT type of VGA monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable attached.
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should automatically show, on the external VGA monitor.
IF not;
There are at least three display options:
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press the Fn key down, and hold it down. At the same time tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
(Give it a few seconds. Sometimes it doesn't happen right away)
Still no?
Hold the Fn key down again, and tap once more on the F8 key.
Is the display off to one side on the external VGA monitor?
Regards,
joecoolvette
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
Computer wont start
The Beeps you are referring to are 'POST' beeps ( Power On Self Test ). In this case one long and one short is indicating a Board Problem. Depending on the Age and Spec of your machine this will be borderline to repair or replace. If you had further specs i'd be happy to advise
Key 'U' defaults to '4'
You have selected the Number Lock which turns the RHS keyboard into a number pad.
The NumLk key also doubles up as a ScrLk key, it is located near the F12 function key. When you press this key it will turn off the Number Lock, also the NumLk LED light will switch off.
HI, I put my compaq presario cq40-310au into hibernation mode but when I came back and the turned it on, nothing appears on the screen. The power button is on so i know there is power. The LED light on...
Welcome to FixYa!
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
When unit is turned on, all lights turn on, even with DMX cable unplugged. All 'Monitor' LED's, 'Power Indicator' and 'DMX Indicator' are on, regardless of 'Switch pack' settings.
The Triacs in the unit probably have shorted. They use a 16 amp Triac in most of these. If none of the stand alone funtions work, this is the likely cause.
2helpful
3answers
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
