Question about Pioneer SD-P62A3-K 62" Rear Projection Television
Pioneer SD-62A5 has red standby light, won't turn on
My tv has the red standby light on, when I push the power button, the green light comes on for a second then the red light comes back on, nothing else. i see amber light thru the back of the tv
  • Anonymous Mar 14, 2014
    rca stuck on standby mode red light only if attempt to turn on the red light goes off but tv will not turn on.
  • Anonymous Mar 21, 2014
    POWER POINT AND AERIAL OK, STANDBY BUTTON DOES NOT SWITCH ON, NO LIGHT COMES ON SO CANT USE REMOTE TO OPERATE TV, TRIED ANOTHER POWER CORD WITH NO LUCK
    Genius:
  • 1,153 Answers
Check C258 video assy.
Posted on Aug 16, 2007
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer rear screen projection tv model #sd p6091-k when i push the standby button in on the front the little standby light glows red like it should but when i push the on button it should turn on and glow...
wait a minute you wanted me to pay you to tell me how to fix it... now you want me to tell you how i did it ...no thanks ...well for 9.99 a month ill tell you...no thanks
Nov 08, 2008 | Televison & Video
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Power
same problem here
Dec 20, 2007 | Pioneer SD-P50A3-K TV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-532HD5 Projection Screen TV won't turn back on.
the problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
Jul 26, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Tv refuses to turn on
your tv is defected need to take in to the tech for repairs.power supply problem or related circuit.good luck
May 20, 2007 | Pioneer SD-P62A5-K TV
Pioneer SD-P62A3-K 62" Rear Projection Television Logo
595 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
