Question about Hotpoint Washing Machines
Hotpoint washer/dryer WDM73a, with broken door hinge. I have a replacement hinge, how do I split door to get hinge into bearings. Is it a case of prising the four lugs around bowl and forcing door apart. There is only one screw visible at door catch.
  • Hotpoint Master
  • 3,463 Answers
Hi.
Remove any screws that you can see, and then prize the two halves apart
Posted on Nov 20, 2008
I need to change a door hinge and bearings on my washing machine
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Oct 13, 2009 | Hotpoint Aquarius WD640 Front Load...
Door hinge is broken on my hotpoint aquarius
Get the model number off the unit and go to sears parts on line. Good luck
Dec 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Dec 27, 2008 | Hotpoint Ultima WD72 Front Load...
Dismantling door of Aquarius 1100 WM63P.
Revove all screws from inside of door then it will split with aid of flat screwdriver.
Nov 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wf220 glass door
undo door hinge from cabinet - held with two screws.
the door halves are held togethet with a few screws which undo and the door will split apart so you can replace the glass
Oct 02, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Fixing of door hinge?
undo screws holding both halves of the door togethet then hinge can be removed. hinge is just held onto the cabinet with a couple of screws
Aug 14, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Replacing Door Hinge
You should be able to access the back of the hinge via the top of the machine removed.
Oct 07, 2007 | Hotpoint Ultima WD72 Front Load...
Wd62 door hinge
yes u do have 2 split the door undo the screws and simply seperate the 2 halves and the 2 lugs that hold the hinge lift off get a small probe to push the broken lugs out of the fittings insert the new hinge put the 2 halves back 2gether screw the screws back up and remount the door 2 the cabinet jobs a gooden good luck
Sep 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
182 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
