Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Tv pixulateing can my wireless router interfere with my tv ? seems that the tv sometimes distorts the pichure
  • Jurie Human Oct 14, 2012
    Yes it can if by some obscure chance a standing reflective wave is close in frequency to your TV carrier wave frequency.It will not interfere with a satelite signal as the dish antenna is to directive.
  • 274 Answers
The router should have no effect on the TV.
If this is a CRT display, then magnetism causes distortion. Be it electric motors, fluorescent lamps, North and South poles of the earth depending on TV's facing, other CRT's, etc....
Posted on Dec 01, 2008
Do different wireless routers have different band widths?
Yes and they can be affected by microwave ovens , wireless phones and a lot of other wireless devices
How To Get Better Wireless Signal and Reduce Wireless Network Interference
Apr 06, 2015 | Belkin N1 Wireless-N Wireless Router
Avoid factors that cause interfrence on the wireless connection.
If you are facing wireless interference on the wireless connection and have already tried resetting and changing wireless channel on the routers and the issue still persists then please check the factors that could cause wireless interference.
The factors you need to check:
1) Make sure that the router is sitting on a wooden desk. If it is sitting on any metallic surface or on top of your Monitor or CPU, please remove it and then keep it on a wooden or glass surface.
2) Some modems may create interference with the router. So it is always advice able that you place your router at least 3 feet away from the modem.
3) Since Your router is having internal antennas, the transmission capability of your router can be increased if your router is mounted vertically rather than keeping it horizontally.
4) Similarly, Make sure that the wireless adapter in your wireless computer is positioned in such a way that it can receive wireless signals generated from the router without any disturbances. If your wireless adapter is hiding inside any enclosed surface you can position it properly.
5) Similarly if you have a cordless phone operating at 2.4 Ghz, It will definitely interfere with the wireless signals generated from the router. Make sure that you keep your cordless phone away from the router or other wireless devices or you can even switch off the phone for sometime for testing purpose.
6) Also try disabling the personal firewalls in your computer like Mcafee, Norton Internet security, Spy ware, Zone alarm etc.
Hope this information allows you to resolve the issue.
on Feb 10, 2010 | Computers & Internet
Acer aspire 5742Z wireless adapter Atheros AR5B97 intermittent fault loses all local wireless signals. Sometimes can I recover after diagnosing problem - sometimes need to reboot to recover. ??
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 17, 2012 | Acer Computers & Internet
My WRT300N seems to have trouble with wireless connections lately. The wireless indicator is a green light, blinking a bit from time to time. Most of the time the router just won't be detected, however...
I suppose you have not suppressed SSID broadcast? Sometimes, interference from neighbouring wireless devices such as Coreless Phone, unshielded powerful speakers etc., may cause interference. Try to keep any other wireless or magnetic device at least 5 - 6 feet away from router.
In the router admin panel, check if you have an option to change the WiFi Channel. usually channel 6 is quite crowded ... try some other channel and see if it is stable. If your router has "Auto" Channel option enabled, please change it to "Fixed" and try.
Mar 22, 2011 | Linksys WRT300N Wireless Router
Once router is configured connection through wireless is not good. Signal strength is excellent however on the router the wireless lights and ethernet light keeps flickering. Am wondering if this has...
hi this does sound like it may be the channel, sometimes if you live in an area where the people are using the same channel normally defaulted to 1 this can cause allot of problems, also things like tv remote's , microwave ovens, anything that can transmit a wave signal can interfere with the wireless signal, i myself have allot of interference in my are so i changed to channel 3, this has helped allot and i do not get much if any interference now so really try experimenting with different channels to see how you get on......hope this helps
Dec 14, 2010 | NetGear MBR624GU Wireless Router
Phillips 28in wide screen tv. Picture OK through Sky, but has two moving distortions on ordinary aerial. Actual picture is good but the distortions moving up the screen make it very difficult to watch.
Even digital signals can be sensitive to electrical interference and using an antenna, you could be getting garbage from any nearby 'noisy' source. Something you might try is to temporarily switch off any electrical device in your home, one at a time and look for changes in the banding you have.
If the antenna you are using is outside (rooftop) and is rotor equipped, try changing the position to see if there is any increase or decrease of the problem. If an indoor antenna, rotate it slowly while watching the TV display for change. You may be able to determine the general direction of the source of interference. Some seemingly innocent devices that can cause problems; - Light dimmers/controllers - Poorly designed network routers - Cordless phones - Power supplies
Dec 01, 2010 | Philips Televison & Video
D-Link DIR-628 wireless connection flickering
You are getting some kind of elecrical/wireless interference. This is difficult to trace. Have you noticed any electrical interference on the TV screen when the wireless connections drops off?
It could be as simple as someone using an arc welder in your area.
Or a neighbour heating up something in their microwave oven (this oven can be faulty and is leaking microwave energy).
If you can identify the source of interference then you may find a solution.
There are a few things you can try.
Get a surge protection power board and connect your computer equipment and wireless router to this power board.
You can configure the wireless router to a different channel, one that is not used by your neighbours so that the wireless signal won't interfer with each other.
Have a look at the signal strength to your computer, if it is weak then move the router away from walls and/or raise the router to a higher location to improve the signal strength.
I hope this info helps you fix your problems.
Sep 26, 2009 | Computers & Internet
My linksys connection sometimes shows that another wireless network by the name of "Green Table" is within range and my connection strength seems to become lower when the "Green Table network" appears. My...
I would go into your settings of your router and change your channel.  It sounds to me like you are getting outside interferance with another router on the same channel.  If you need more assistance, please let me know and I will help you as much as I can.
May 31, 2009 | Linksys Wireless-G WRT54GS Router...
Philips Wireless Router
many things can interfere with the signal
  • distance from router
  • brick Walls
  • wireless phones near router
  • aerial loose on router
sometimes, wrapping aluminum foil, around the aerial to make it bigger can help.
good luck
Mar 15, 2008 | Computers & Internet
D link router
This could be due to many factors. A few to look at is:
Move the router closer to the PC
Update the drivers on the PC, making sure the wireless network card is not using windows drivers alone (re-installing the drivers from the CD or website will fix this.)
If the wirless network on the PC is a USB pen type, then change it to a different port. Or, it may need USB 2. If your PC does not have this, you can purchase a USB 2 PCI card from ebay for under £10.
Try unplugging any DECT (digital cordless) phones in the house, as they may be interfering.
Feb 03, 2008 | D-Link DI 514 Wireless Router (DI-514)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
59 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
