Question about Ricoh FT3713 Copier
Ricoh Toner for FT3313 and FT3713
I know the developer is the same for both of these units; however, one says it takes a toner 310 and the other says it takes a toner 320. How can I find out if these are really different or the same item? I have found service manuals but not flow chart types of trouble shooting manuals. The FT3713 is printing blank pages and I'd like to be able to learn how to do a full PM on both machines. It might simply be that the 310 really does not work in the FT 3713. Thanks.
  • 42 Answers
When the developer is the same the toner is the same.The toner drops in to the developer,thus the toner must be the same.They just package it different to be a pain!
Posted on Dec 11, 2008
RICOH MP 3350B ask for toner even having a new one
Take out the toner cartridge and shake it vigorously. When they sit for a long time the powder tends to clump.
Nov 19, 2014 | Ricoh Office Equipment & Supplies
Lanier 5227 add toner message
I take it you have installed a new toner???? Do oyu know the last time the drum & developer unit was replaced?? It is sold as a unit with the developer in the unit. It is a customer part to replace. If these parts were replaced resently, the problem could be in the toner holding unit that you put the toner bottle into... There has been some up dates to that unit > they improved the fin's that moves the toner into the developer unit... Good Luck
Feb 23, 2012 | Ricoh Aficio 250 Copier
Ricoh afficio 1045 & ricoh 450 toner is mixed in ricoh fw 780 now background and negative image is coming what can i do plz give some idea
firstly you need to remove the developer and vacume the developer unit and magnetic developer roller.
Put in new developer and correct toner in toner unit.
Call service...
After replacement there is a sequence wich needs to be done, for developer initialization.
Aug 16, 2011 | Ricoh FW 780 Black and White Copier
How do i reset it. The toner cannot get to the developer until I manually filed in toner to the developer.
looke my friend this problem assume many causes first step 1- check that motor bottle is rolling 2- check that housing toner is not blockage on it 3- check that this tank belong to machine it's not from another model 4- check that TD sensor is feel with toner obviously
Apr 04, 2011 | Ricoh FT3713 Copier
I have a Ricoh aficio 2018D problem is SC390 Code i reples PCU Unit Lower unit/Drum & Developer but sc390 code problem not solw. Please help Me.
The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first.
Check that the toner bottle is empty and most of the toner in the development unit is depleted.Add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Ricoh Office Equipment & Supplies
Toner light on and have cleaned overflow tray still on will not reset new toner in
ok mate. clean the toner supply unit where the toner fits in. the unit is blocked with toner inside. that is why it is not supplying the toner to the machine.
Dec 08, 2010 | Ricoh FT3713 Copier
Ricoh 4220 copier. I replaced toner cartridge and
I suggest removing the toner, and visually inspecting it, make sure the sealing tab has been removed, give it a really good shake, as the toner may have settled in storage. re-insert the cartridge making sure it goes in the right way.
If you can hear a slight 'clicking' noise it's adding toner and pumping it into the developer unit, some machines take 2 minutes, some take 6..
Failing that, lift the platen cover and do a few black copies, so you force the machine to add toner.
Goodluck.
Oct 16, 2009 | Ricoh FT3713 Copier
Ricoh ft3713 toner overflow
remove the toner bottle, open the back cover and look for the small DIP Switch turn on and off, by doing this you are forcing the machine to come out from add toner condition. Then you do 20 sky shoot.
Oct 24, 2008 | Ricoh FT3713 Copier
Ricoh ft3713
Please properly installed the Drum Unit
Sep 22, 2008 | Ricoh FT3713 Copier
195 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
