Question about Zenith VCS442 VHS VCR
VCR tape stuck
Hi. I was fast forwarding the tape in a VCR-DVD combo. When I noticed that it went beyond the point where I needed it to be, I then without stopping the tape just pressed the rewind button. Now the tape is stuck in the VCR. Do you know if this is a mechanical problem and what I can do? Thanks
    Genius:
  • 1,139 Answers
Yes, it is a mechanical problem. While the tape is in fast forward the gears are engaged and locked to provide drive to the spindel on the right, however when you press the rewind button without hitting stop, the gears try to engage the spindel on the left without stoping and reversing (changing rotational positioning), this causes the motor to stop (this emulates a tape jam)the tope is left in and the unload mechanism never spools the tape back in because the motor has stopped. To free the tape, what I do is open up the unit and find the main motor check to see if the belt has slipped, if it has not try to manually spin the motor to engage the unload mechanism and eject the tape.
Posted on Sep 16, 2007
6313cg - stuck tape
If the eject mechanism is belt driven, check to see that the belt not slipping or off the pulley. If gear driven check to see if the motor that powers the eject cycle is receiving power when called for.
Feb 16, 2014 | Sylvania 6313CG 13-Inch TV VCR Combo
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
VCR Not Accepting Certain VHS Tape
I had this happen once and all I did to correct it was to fast forward it just slightly or manually wind it past the leader strip (the clear or white part at the beginning). To do it manually, there is a small hole you must insert a toothpick (or something else as small) to push the pin in and then advance it with your finger while holding the pin in. Hope this helps.
Oct 15, 2008 | Philips Magnavox DVD/VCR Dual Player
Fast forward of Disk on my Go.Video2140
Try keeping pressed the skip button to do fast forward on a Disc.
Apr 22, 2008 | GoVideo Go Video DVD/VCR Combo
VCR won't accept new recording tape
I asked earlyer but i can't find my questin that was submitted earler today i gave you my email address with no results. I want to know where the nearest tv vcr reparemand is to Spencer okla my email is davidcurle@sbcglobal.net and my phone No.is 580-782-2888 My mother is moving to Spincer Okla. and needs her vcr forward and reverse fixed,in her emerson tv/vcr combo
Apr 02, 2008 | Emerson EWC1902 19 in. TV/VCR Combo
DMR-EZ47VK Up-Converting 1080p DVD-Recorder/VCR Combo
I think the problem with the tapes stopping is that there is too much tension on the tape. Try another VCR and try to see if you have the same problem playing the tape. Forward and reverse through the part that causes the player to stop. It is also possible that the tape inside the vcr has become twisted or stuck. One can fix this if they are very careful opening the video tape. However, I would not recommend this for most people
Mike
Dec 22, 2007 | Lite On LVW-5045 DVD Recorder
Vcr trouble
this combo unit as far as i know has only one power source which is in the vcr unit. if the vcr has a problem it affects the tv likewise. i beleive u did removed the tape, but unfortunately you misaligned the mechanism of the vcr which will in turn sense an error causing the automatic shuts off of the vcr and likewise the tv. u need to bring it to a qualified service technician if u dont know anything about this.
Jan 05, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Zenith VCS442 VHS VCR Logo
340 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
