Question about ASUS W2P (W2PB-7K003C) PC Notebook
Battery doesn't work
My battery has never worked and I would like a new one sent to me. Please help.
Model: W2P
MB Ver.: W2PB
71N0AG001655
W2PB-7K003M
Check Number: 5139
Warranty:24M
Flash rom battery location mb-8500tac
your cmos battery is the size of a nickle
Dec 25, 2013 | Biostar Mb, Mb-8500tac-a Ver.5
My ASUS W2P PC notebook screen developed vertical lines and now several months later the screen is very bright. I've backup my data ready for the screen to fail any day now. I have attached my Notebook to...
Since you have done the first step, hooking to another display, I would say it is probably an issue with the lcd panel... something that often comes from impact damage, but can also simply be a failure.
If the machine is not obviously damaged and is less than a year old I would say take it back to the purchase location as there is no repairs provided by Asus under MFG warranty, they simply replace. Otherwise, I would say try to locate a new panel online or take the machine to a qualified technician;
//halfs
Feb 16, 2010 | ASUS W2P (W2PB-7K003C) PC Notebook
M955g v: 3.0a Bios changes time and date back
It looks like you have the latest BIOS, but I would flash it again, evidently something went wrong, if flashing with v3.0 doesn't work, go to the ver before and re-flash.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=302&CategoryID=1&DetailName=Bios&MenuID=1&LanID=0
I hope this helps.
Jul 08, 2009 | PC Chips M955G Motherboard
ASUS A8JP Will Not Power On
"When the charger is connected to an AC source, the green LED shines steady and bright."
are you talking about the led on the AC-adaptor? cause if its that led that dims down, its a defective ac-adapter (even tho you still might not believe me). replace it and try again.
how would you know that the battery is fully charged?
please rate my solution after you have tested if it works out for you :)
May 19, 2009 | ASUS A8Jp Notebook
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
Motherboard doesn´t work
You also have a manual for the Biostar? Find the serial No# printed on the Mb. Usaully found on a white sticker found on the serial port. With the serial No# in hand look up your board on Biostar's web site. Download the manual. You will find what CPU's your MB can take.
Dec 04, 2007 | Biostar P4M800-M7A Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Boot problems
Hi, since everything is new, you can probably ask your source to replace the motherboard since it looks like a bios/mb problem. If for some reason, you can not, them maybe you would want to try and update the bios. Their latest bios version is 1804 (for Asus P5LD2) and may be downloaded from http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5LD2. This is only if you are comfortable flashing since it involves some risk. Further, you have to follow carefully the flashing instructions. Bios are very specific to model and version of the mb. Hope this works out for you and please let me know how things turn up. Regards.
Apr 14, 2007 | ASUS P5LD2 Motherboard
ASUS W2P (W2PB-7K003C) PC Notebook Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
