Question about Garmin nuvi 200W GPS Receiver
My Garmin Nuvi 200 w dont work
I was trying to update the GPS and now if I want to use it-there is a message display that reads:''No detailed maps found that support routing.The nuvi cannot be used without them.'' I have tried to format the whole GPS and load my friends data on my gps(we both got the same model) but the same message appear. I hope you can help me please.
  • 2 more comments
  • jpmotley2323 Mar 28, 2009
    Screen reads " No dtailed maps that support routing" I have no idea where to start with this.
  • yanko_m Apr 13, 2009
    I have the exact same problem, even with what I consider to be fast internet it took 6 hours to download the 2 Gig update and break my nuvi 200w, I am following the directions and using the MapInstall program, located in START>Programs>Garmin>Mapinstall, so far looks like its going to work, I only selected the areas that I felt I would travel to, might want to double check that you can get to your destination before you leave.
  • Anonymous Apr 26, 2009
    Not one of the solutions has fixed this problem. Garmin must be clueless.
  • sfbabster May 11, 2010
    Thanks, this worked great except my Garmin only has enough space for half the lower 48 states in North America. It's supposed to have the entire lower 48 states loaded on it.
When you downloaded and installed the WebUpdater, you also got a program called MapInstall. Use it, pick the states/areas you want to install and watch the bar on the right. It will turn green and "fill up" as it calculates the amount of space needed on your gps vs. the amount available. When you have chosen too much it will let you know by turning all red.
You can ignore that huge 2GB executable file Garmin had you download. I think it's supposed to be a self extractor/application for installing the maps but has three drawbacks: One, it's painfully slow; Two, it does not work. It will go way past 100% completed and then give you a message that it failed to update your maps; and Three, once it begins the update it erases your old maps leaving you with a Nuvi that's useless without them. I tried it three times, with three different machines (after waiting 45 minutes for the Garmin helpless desk to tell me it was my chipset that was causing the problem. Nope) and got the same result. This leads me to believe the self extractor is flawed.
Once you have chosen all your states or provinces, click on the finish button and it will load those maps and you'll have a usable, updated Nuvi again. I spent the best part of a day with the .exe file because the process was so slow, and when I did it the above way it took maybe 20 minutes.
Good luck, hope you see this solution.
Posted on Feb 14, 2009
After searching Garmin's site I found that you can go in and make room for more maps by deleting some of the languages that you do not need, on your device, you can open the "My Computer" icon and open the folder to your device after it is connected.
Posted on Apr 13, 2009
My garmin nuvi 200 says no detailed maps found
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message "No Detailed Maps That Support Autorouting."?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message "No Detailed Maps That Support Autorouting" disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for "Getting your unlock codes".If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the "No Detailed Maps That Support Autorouting" message.
Aug 14, 2012 | Garmin Nuvi 200 Automotive Gps Receiver
My garmin nuvi 200 it say no detailed maps
my garmin 200 nuvi say no detailed maps found that support routing
May 21, 2010 | Garmin nuvi 200 Car GPS Receiver
I have a nuvi 200 and I live in Jacksonville FL there are many new roads, new highways and I drive a lot and want to update my GPS so I dont come to a lot of dead ends. What do I do?
You can update the maps using either Garmin or other third party maps. The accuracy will depend on how old the mapping data was that is used to create the map. So you want to find out if the map in that area is recently updated. You may also find that a regional map may show the details in some areas where a larger map won't.
To upgrade using Garmin you just go to garmins website
You may find the map update is free or you may update for a fee or get a lifetime update subscription. The gps is hooked up through the usb cable and will download and instal the updates. It's painless (sort of ;-]) and quick.
Apr 23, 2010 | Garmin nuvi® 200 Car GPS Receiver
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
I had the same issue..what a pain in the ****.
I came up with a solution that worked for me.
After the update i deleted gmapprom.img and then created my own map using the garmin MapInstall program. start>programs>garmin>mapinstall
Apr 11, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
GPS Issue
You're unit is probably missing the gmapprom.img file (failed update maybe?).
Try contacting Garmin - if you've got registered maps they may send you another copy (although big file - 100+MB)
Jan 12, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Garmin nuvi 200W GPS Receiver Logo
506 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
