Question about Dishwashers
Frigidaire Dishwasher Leaks and Shows ''uF'' and ''Er''
I baught a Frigidaire FDB4050LHS1 dishwasher from Lowe's in October of 2008. It regularly leaks from the bottom of the door and displays error code ''uF'' and ''Er''. Both error codes are shown in succession, and never alone. The sound insulation behind the bottom edge of the door is completely soaked and dripping. I have taken note of the cycle, time of day, water temperature, soap used (if any), fullness of the washer, and nothing seems consistant. The error codes leaking seem to be random as they do not corrolate to anything. I even get the code when running an empty washer without any soap.
  • Anonymous Apr 13, 2009
    I have the same problem however it only does it when the setting is on ultimate scrub.
jsrock516
  • 5911 Answers
SOURCE: Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Posted on Jun 05, 2007
futureloginn
  • 734 Answers
SOURCE: Brand new dishwasher installed and water leaks out bottom of door
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Posted on Dec 12, 2008
futureloginn
  • 734 Answers
SOURCE: Frigidaire Dishwasher leaking but not from door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  • 686 Answers
SOURCE: Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
Posted on May 01, 2009
  • 109 Answers
SOURCE: Leaks water from bottom of door. Error code E7 ?
LXi H machines do not have rubber door seals, they have overlapping baffles to allow breathing of wash tank. If the leak occurs from no use over a period of time, you will have a dirty or worn fill vale letting water trickle into the wash tank. LX's don't have an overflow as they rely on probes and a machine turned on to control the water level. Repair kit is available, but it may just be some scale or dirt holding the seat open.
Posted on Aug 14, 2009
Dishwasher is sputtering while running. Almost as if it is shorting out or something in the motor is skipping.
Dishwasher Sounds that Could Indicate a Problem - YouTube
? 2:22
https://www.youtube.com/watch?v=bEBECtCoLTI
Jun 17, 2010 - Uploaded by GE Appliances
Certain sounds may indicate a problem with dishwasher loading, water fill, or an interrupted cycle. Find more ... Does it run whileopen?
5 Common Dishwasher Problems - APWagner Appliance ...
https://apwagner.wordpress.com/2008/.../5-common-dishwasher-proble...
May 20, 2008 - Running the dishwasher regularly may help prevent any seals from ...Question 2: Why aren't my dishes dry when the dishwasher finishes?
Jan 19, 2016 | Frigidaire Dishwashers
Frigidaire dishwasher reads Er clean
http://www.appliancerepairlesson.com/2012/12/15/frigidaire-dishwasher-error-code-er-keypad-code
It could be thinking you are pressing a button for too long.
Try the above link answer for reset.
Or unfortunately it can be a shorted keypad.
Dec 01, 2015 | Frigidaire Dishwashers
How do I reset my Frigidaire dishwasher? eR light is flashing
Good Afternoon Sammy, thank you for your inquiry!
Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
Mar 21, 2015 | Frigidaire Dishwashers
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
What does Er and uF mean. My dishwasher was linking water.
On mine it was Er meant "error" just generic for somethings wrong, (dumb I know!) and the uF means unit failure. I know it sounds so dang dumb. It is merely the computer\'s way of telling us something is not right. Hope it helps, but please don\'t ignore those codes they really are put there for OUR safety, Be Well.
Sep 29, 2014 | Frigidaire Dishwashers
After the cycle starts, water leaks out of the bottom of the machine and into the basement
I would call for service. many probabilities and none are good. it is fixable but for a diy'er it could get to be a bit much.
Apr 29, 2012 | Frigidaire Professional Series 24 in....
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
559 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
