Question about Sony XM-2200GTX Car Audio Amplifier
I have a question?
How do I check the powersupply section for any damaged components. how can i tell and how would i fix it?
    Problem Solver:
  • 14 Answers
Normally if the power section components are damaged you will see a burnt mark on the p c b(printed ciurcuit board). rather than haveing it repaired(which can be very costly,id recomend getting a new unit,that is if its a cheap one. if its a more expensive unit then see how much it is to repair but be prepared to pay a fair bit to get it done.
Posted on Apr 11, 2007
Sansui crt tv use str5q1265 no on powersupply
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Mar 11, 2017 | Sansui Televison & Video
How do I fix samsung tv no picture just sound I replaced the powersupply/led board Part no. BN4400666A and still the same.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jul 06, 2015 | Samsung Televison & Video
My APEX tv model no.pf2720........does not want to
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
If the power supply regulator section work properly, check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked above.
Oct 20, 2014 | Televison & Video
Set dead powersupply ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 11, 2014 | Samsung CW29M64NS 29" TV
19 in lcd sharp keeps blowing fuse
check the primary section of the powersupply mostly diodes and transistors inside and alo there filters.
Feb 06, 2013 | Sharp 32R-S50 32" TV
Tv powersupply fuse is blow, replas new fuse but same problam.
Hello
There is some short circuit in the power retulator side of your TV. Never put a fuse and switch it ON, as it may damage more components in your system. A power voltage surge can damage the regulator side of your TV. There is a short [Direct short] occured inside it. Check the rectifier section first, with the help of a multimeter set to Ohms range. Measure the resistance accross the main filtler capacitor. if it seems to be very low, say less than 12 Ohms or so, resolder out the mains rectifier stalk, or diodes, whichever may used, and chck it for juction short. If shorted, replace it. Check out the switching regulator also. In most cases this regulator may get damaged due to power supply spikes. In some sets, there is a MOV [Metal oxide veristor], connected accross the main AC line, after the switching point. this component is used as a protection, and if there comes any overvoltage or voltage spikes, this veristor will get shorted, blowing off the fuse, and further damage is prevented. Check this also. This component will look like a disc capacitor, normally black or green in color. Check these, and further check most of the power regulator components, such as Zener diodes for short. Before switch on your TV. make sure you have tested all the componets in the power regulator side. OK.
Jan 28, 2011 | Hitachi C29-F800S 29" TV
TV went black while I was watching and will not start back up
hello! what u have not told is whether the power on light is still showing . but its adivable for a technician to check the powersupply and Horizontal section for any damaged part becouse there's posibilty of unstable current burning something.
bye
Sep 04, 2009 | Televison & Video
I Have A Compaq Presario That Will Not Power Up.
It sounds like your power supply unit as some leaky components, normally the bad powersupply unit show these types of symptoms. Try borrowing a powersupply unit from a friend that is similar to yours and replace to check if the powersupply unit is the culprit. If cornfirm PSU, than you neet to get yours fixed.
Nov 11, 2008 | Compaq Presario 5000 PC Desktop
Dead Motherboard?
Testing motherboard components is beyond most users and computer shops these days, especially when it costs more to test than a new board. What you can do is do a visual inspection for physical damage; common items are -broken connectors -capacitors with rounded tops or corrosion at the base -burnt or scorched components or spots on the motherboard -corrosion on the motherboard especially around connectors, solder joints and the CMOS battery. On machines that sit idle for some time when I find physical damage its typically from high humidity, power spikes, dead CMOS batteries and damaged capacitors. Even if I find something physical I will usually replace the motherboard rather than try to fix it and run the real chance of it failing again. More often than not the physical problem we find is usually a symptom and not the actual underlying cause. Since the cost of repair parts is small compared to my labor its more cost efficient for my customers to replace the defective part with a new, warranted part. That minimized the chance of having to pay for my labor again. On the other hand if you want to experiment for the experience then go at it and have fun. Soldering correctly without damaging the part or the board is an definitely an art that takes time to learn.
Feb 28, 2007 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Playing my music, then amp goes out? anyway to fix it?
Looks to me like u are having a power problem. Check if power is going to your amp, if yes, check the fuse on the amp. If ok, check the powersupply section for any damage components and replace.
Dec 18, 2006 | Sony XM-2200GTX Car Audio Amplifier
Sony XM-2200GTX Car Audio Amplifier Logo
41 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
