Question about Car Audio & Video
I need to find an installer manual for my car radio wires
Hi i need to find what wires connect to which with my new cd player in my car Crysler sebring convertible 04. I Don't have an owners manual and I don't want to connect them wrong. I'm replacing the stock one. If I could get help knowing which is which on the old one that would be great. Because the new wires say what they are.
    Scholar:
  • 71 Answers
This is for a 2002 let me know if yours are different and ill try and find it for you,
Constant 12V+ Pink/White  Switched 12V+ Red/White  Ground Black  Illumination Orange/Brown  Dimmer Black/Green  Antenna Right Rear  Front Speakers 6 1/2" Doors Left Front (+) Green  Left Front (-) Brown/Red  Right Front (+) Purple  Right Front (-) Blue/Red  Rear Speakers 6" x 9" Side Panels Left Rear (+) Brown/Yellow  Left Rear (-) Brown/Blue  Right Rear (+) Blue/White  Right Rear (-) Blue/Orange
Posted on Nov 27, 2008
Installation-wiring
Performance Teknique might be able to supply a manual and/or wiring instructions.
Jan 01, 2014 | Performance Teknique Icbm-7348 Cd Mp3 Wma...
Cd stuck in cd player cannot be removed have replacement radio with computer components but have to remove old radio/cd player first how is this done?
hi may I clarify you are asking for a wiring instruction for your new car stereo or you are asking for mounting instruction?if so please give me the brand and model of your new radio and if you can post a picture of the car stereo back connection wiring .so I can help you in wiring connection of it. thank you...
Aug 22, 2011 | Car Audio & Video
Hi, i have a 2004 dodge ram 1500 with the infinity stereo system. The factory cd player broke and i tried to install a new cd player, i bought the right wiring harrness and conected it. But the speakers...
it sounds like you need to turn on our amplifier. this is simple and easy to do just by connecting the blue/white wire off of the back of the radio to the blue wire on the harness that connects to the factory harness.
Jul 02, 2011 | Car Audio & Video
Hi! i just installed myself a new Dual Cd Player Xd 1222 on my ford focus 2002 4 door. The problem is when i start my car.. The dual reset every information like the bass and treble and all of the stuff....
This just means that you do not have your remote or memory cable connected to the correct power source. You need to connect this cable to a power source that continously runs. Underneath the driver side should be a fuse box. Connect the remote/memory cable to a fuse that runs, like maybe the old radio fuse. A schematic of the wiring for your vehicle would help you out a lot. This will show you the best source to connect the cable.
May 18, 2010 | Car Audio & Video
97 grand cherokee laredo wiring cd player install. can get power to it but have to have battery and ignition switch hooked together how to do it the other way? cause it erases my memory on the cd player...
Hi the ignition wire needs constant power thats how it saves your memory. You will need a test light to find the wire that is constant power. With the key off touch the light tester to the power wires from the radio harness the one that turns the light on with the key off is the ignition wire and is to be connected to the ignition wire from the radio.
Feb 05, 2010 | Cherokee (REF) AM/FM Stereo with CD Player...
Wiring difference
If your installing a stock radio/cd player from another Dodge the wiring plug is the same and will fit.If your installing a aftermarket radio/cd player(JVC,Pioneer,etc)you will need to buy a adapter plug that wires up to the radio and is a direct fit to your factory wire harness,so your not cutting your wires.When you buy the adapter plug it comes with a wire diagram of which wire is what.Your aftermarket radio should have a diagram also,either on it or in the manual.Hope this helps you.
Mar 04, 2009 | 2002 Dodge Caravan
New cd player installed but no sound!!!!!
First be sure thet all wires are properly connected and that the units output sound controls are adjusted (balance & fade etc.)
www.installdr.com has many valueable resources that may assist you.
Good luck
Feb 22, 2009 | JVC KD-G110 CD Player
Radio does not come on
There are a few things you may need to check:
1.Make sure you have 12v to the yellow wire on the harness with a good ground at the black wire, and the red wire should be your ignition switched acc wire.
2.Make sure your fuse under the radios wire harness connector is good.
If all of that is in order hook it up, turn the key on and hit the on/off button on the cd player, most aftermarket radios require you to manually turn them on the first time, and anytime the battery is disconnected. If is still doesn't work the unit is more than likely bad.
Feb 20, 2009 | Pioneer DEH-1600 CD Player
Problem with factory radio
you probly need a wiring harness....if this is the first aftermarket cd player in the truck... go to car audio place round town and ask for a wiring harness for your model truck....the wires will then be color coded.....hopefully this helps
Jan 26, 2009 | Car Audio & Video
Car Audio & Video Logo
154 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
