Question about Proview HX303 30 in. HD-Ready LCD Television
Screen turns pink tint when trying to watch movies.
1.)  I have hooked up my PS3 to my proview 3200 lcd tv. HD cable and all. But when I put a movie in the screen was pink. The same thing happened when I tried my dvd player. But when I hooked up the HD cable it went away and worked fine. What do I do to get rid of the pink tint so I can view it normally. It looks great when I play games.
2.)  When I put my satellite box to my tv I do not get HD channels. There is a grey rectangular shape on both sides from the top to the bottom, rather than the black strips. I have already tried adjusting to 720p and 420p and 1080i but none of it works. When I press the button on the box for 420p it takes up the whole screen but to the right and i can ony see the bottom.
  • 2 more comments
  • Anonymous Dec 01, 2008
    • Same problem. Cable with HDMI works great. Games are great. But when I try to play movies I get a pink hue. Also, sometimes the screen gets that snowy look and blinks on and off. I have had my PS3 hooked up to my 42"Westinghouse LCD for 5 months and only recently have I had this problem.
  • pinkscrnhell Jan 13, 2009
    I have the the exact same problem with my Westinghouse TX-42F430S. I didn't have any problems for approximately five months, but, suddenly, the sound went out when using an HDMI cable and all the movies I try to play start out in a pink hue. I have found that if I repeatedly unplug and then replug the HDMI cable, sooner or later, the correct color will appear. Sometimes, though, it will have a snowy screen and just flash from snowy to black and back.
    Unfortunately, the only solution I've found is to plug the HDMI cable into all of the HDMI ports until the picture shows up correctly, which is a very poor solution.
  • ansmitty2004 Jan 22, 2009
    yesterday, 01/21/2009, my westinghouse 42" 1080p set went pink with blu-ray movies and no sound from my PS3 and perfect picture but no sound with my games!!! This is obviously a recurring problem after i searched it!!! my set is over a year old and has had my PS3 hooked to it for a while but just started doing this!!! I am dumbfounded and amazed i didn't know bout this before or i would have purchased a differnet TV set!!!
  • spaganya Mar 21, 2009
    I have a westinghouse 42 in 1080p with a ps3 hooked up to it, yesterday when i tried to play a blu ray disk on my ps3 the picture came out pink tinted. Following the advise of what i saw online, i unplugged and replugged the HDMI cable from the ps3 to the tv a few times and it eventually corrected itself, then had no sound, had to do it again to get BOTH sound and picture... whats going on?
  • 223 Answers
SOURCE: Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
Posted on Oct 03, 2008
skotkolr
  • 558 Answers
SOURCE: no picture
bad capacitors in the power board area these can be replaced and soldering is required to replace them
Posted on Dec 09, 2008
SOURCE: proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
Posted on Jun 22, 2009
  • 3 Answers
SOURCE: Proview LCD TV
Mee too.. whats up with that? im gonna call proview technical support to see whats goin on
Posted on Sep 06, 2009
budmrtn
  • 11361 Answers
SOURCE: ProView PA40JK1A screen just went black one day.
No, There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 17, 2009
Testimonial: "Thanks for the quick reply. Very helpful."
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Green tint to picture when dvi cable is connected
The tv will show correctly in 720p mode. Cable box and PS3 must be set to display in 720p or the green tint will remain. For the PS3 I return it to 1080p when I am about to play a game, blu-rays and dvd's can only play in 720p.
Dec 15, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Sep 17, 2008 | Proview HX303 30 in. HD-Ready LCD...
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Wavy picture after hooking up component switch
What you are using is probably an active switch. Many of the movies have macrovision protection. The active switch is having problems to deal with sync pulses from the video containing the macro vision protection.
Jerry G.
Jun 19, 2008 | Televison & Video
Samsung LN-T3732H 37" LCD
T'Con board fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 11, 2017 | Samsung LN-R328W 32 in. HD-Ready LCD...
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Ps3 won't play blue ray discs
try reseting the drive by holding down the eject button for 10 seconds
Nov 15, 2007 | Sony Playstation 3 (PS3) Console
Proview HX303 30 in. HD-Ready LCD Television Logo
1,230 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
archetrix
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
