Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Evaparator motor access
Catriver, What is the best way to access the motor? I have the same problem and was wondering if I do through the freezer or through the back side? Thanks.
  • todd nason Dec 18, 2006
    My model is 596.7727290. The part number you list is different that shows up on the Sears website. Are we on the same website?
    President:
  • 878 Answers
Yosh, you are going to get it from the inside of the freezer. Lift the whole door off to get it out of the way. Remove the ice-maker if there is one by removing the quarter inch screws holding it in. Unplug the harness. The vent grill has two clips toward the top side that push inward and it pulls off. Remove the quarter inch screws holding the back panel in place. Remove the thermistor cover on the right by pushing in on the tab and remove the thermistor from the cover (slides out). Now you can remove the back panel. The motor is held in with a plastic mount that will push in and release from the bottom. Pull the fan off first. Careful of the sharp evaporator fins, easy to cut yourself. It's ok to bend them a little just straighten them out when finished. Take your time and observe...this is not a hard job...Catriver..post back...This is for model starting in 596.
Posted on Dec 18, 2006
  • Ron Marek
    Ron Marek Dec 18, 2006
    Im not really sure what post you were looking at. The instructions I gave should be accurate. Your part number for the evap fan motor is 10513801 which switches to 10513803. Check it out herehttp://www.repairclinic.com/0080.asp Catriver.
SOURCE:
Hi, my Samsung refrigerator works, but the freezer does not.
check if fan runs and if evaparator is pack with frost might be a probleme with defrost
Jan 06, 2015 | Samsung Refrigerators
Master-Bilt commercial freezer Bearings
If you can access the condenser fan, jam it with a screwdriver handle so it can't revolve. switch on and see if the noise still appears. If not, change the fan motor. If so, change the compressor.. Don't let the compressor run without the fan operating more than to test for the noise.
Apr 25, 2014 | Freezers
Evaparator fan motor not working what can be the problem.
The problem could be the defrost timer/control board or a bad fan motor....
Check for power at the motor... if there is power then the motor is bad...
if no power then the controlboard or the defrost timer control is bad...
make sure there is no ice stopping the fan...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | KitchenAid Refrigerators
Fridge is look warm but running freezer remains frozen
check your evaparator fan motor if its not working it wont pass the air to the fridge.. its inside the freezer possibly might have to remove back wall inside
Jan 30, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer works but refrigerator doesnt
temp control to high .settin in freezer set to coldest, starving bottom of cold air, evaparator is freezing up
Aug 26, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Very loud noise and the middle bit between the fridge and freezer isvery hot to touch with my powepiont model no TRF295 what shall i do?
loud noise comes from moving parts such condensor fan motor, evaparator fan motor. be sure they are nt hitting shroud. other is compressor-may be going bad. heat in middle is coming from mullion heater,as long as it doesnt melt gasket or short out, trip breaker should be ok.
Aug 26, 2009 | Refrigerators
Water in the bottom of the refrigerator
you have to take out the back postion in side the freezer please ulplug the refrigerator under the evaparator is the drain throw hot water in there
Mar 30, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Jenn air refridgerator model 2089HEP, less than one month old, top section will not cool below 60 degrees although freezer seems okay. Any ideas? Any ideas with the warrenty versus a return?
Susan, sounds like you evaporator fan motor is not moving the air. Open the freezer section, you should hear a fan running. If not, then that's the problem. If it is running then it could be a damper issue. Call for factory service, still under warranty. If the cat can't fix it in the same day, have them bring out a new one. Catriver
Aug 03, 2008 | Refrigerators
Noise
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Nov 10, 2007 | Hotpoint HSS25GFP Side by Side...
Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
Mar 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
93 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
