Computers & Internet Logo
Anonymous Posted on May 08, 2012
If 1kg = 2.2lb How many kg is 150lb
The conversion factor is 1kg = 2.2lb How many kilograms are in 150lbs
Anonymous
Level 3:
  • Master 6,771 Answers
  • Posted on May 09, 2012
Anonymous
Master
Level 3:
Answers
6771
Questions
0
Helped
1779184
Points
21413
How many cups in 300 kilog
10 kg = 676.2805 tbsp
20 kg = 1352.5609 tbsp
30 kg = 2028.8414 tbsp
40 kg = 2705.1218 tbsp
50 kg = 3381.4023 tbsp
60 kg = 4057.6827 tbsp
70 kg = 4733.9632 tbsp
80 kg = 5410.2436 tbsp
90 kg = 6086.5241 tbsp
100 kg = 6762.8045 tbsp
110 kg = 7439.085 tbsp
120 kg = 8115.3654 tbsp
130 kg = 8791.6459 tbsp
140 kg = 9467.9264 tbsp
150 kg = 10144.2068 tbsp
160 kg = 10820.4873 tbsp
170 kg = 11496.7677 tbsp
180 kg = 12173.0482 tbsp
190 kg = 12849.3286 tbsp
200 kg = 13525.6091 tbsp
210 kg = 14201.8895 tbsp
220 kg = 14878.17 tbsp
230 kg = 15554.4504 tbsp
240 kg = 16230.7309 tbsp
250 kg = 16907.0114 tbsp
260 kg = 17583.2918 tbsp
270 kg = 18259.5723 tbsp
280 kg = 18935.8527 tbsp
290 kg = 19612.1332 tbsp
300 kg = 20288.4136 tbsp
310 kg = 20964.6941 tbsp
320 kg = 21640.9745 tbsp
330 kg = 22317.255 tbsp
340 kg = 22993.5354 tbsp
350 kg = 23669.8159 tbsp
360 kg = 24346.0963 tbsp
370 kg = 25022.3768 tbsp
380 kg = 25698.6573 tbsp
390 kg = 26374.9377 tbsp
400 kg = 27051.2182 tbsp
410 kg = 27727.4986 tbsp
420 kg = 28403.7791 tbsp
430 kg = 29080.0595 tbsp
440 kg = 29756.34 tbsp
450 kg = 30432.6204 tbsp
460 kg = 31108.9009 tbsp
470 kg = 31785.1813 tbsp
480 kg = 32461.4618 tbsp
490 kg = 33137.7422 tbsp
500 kg = 33814.0227 tbsp 510 kg = 34490.3032 tbsp
520 kg = 35166.5836 tbsp
530 kg = 35842.8641 tbsp
540 kg = 36519.1445 tbsp
550 kg = 37195.425 tbsp
560 kg = 37871.7054 tbsp
570 kg = 38547.9859 tbsp
580 kg = 39224.2663 tbsp
590 kg = 39900.5468 tbsp
600 kg = 40576.8272 tbsp
610 kg = 41253.1077 tbsp
620 kg = 41929.3882 tbsp
630 kg = 42605.6686 tbsp
640 kg = 43281.9491 tbsp
650 kg = 43958.2295 tbsp
660 kg = 44634.51 tbsp
670 kg = 45310.7904 tbsp
680 kg = 45987.0709 tbsp
690 kg = 46663.3513 tbsp
700 kg = 47339.6318 tbsp
710 kg = 48015.9122 tbsp
720 kg = 48692.1927 tbsp
730 kg = 49368.4731 tbsp
740 kg = 50044.7536 tbsp
750 kg = 50721.0341 tbsp
760 kg = 51397.3145 tbsp
770 kg = 52073.595 tbsp
780 kg = 52749.8754 tbsp
790 kg = 53426.1559 tbsp
800 kg = 54102.4363 tbsp
810 kg = 54778.7168 tbsp
820 kg = 55454.9972 tbsp
830 kg = 56131.2777 tbsp
840 kg = 56807.5581 tbsp
850 kg = 57483.8386 tbsp
860 kg = 58160.119 tbsp
870 kg = 58836.3995 tbsp
880 kg = 59512.68 tbsp
890 kg = 60188.9604 tbsp
900 kg = 60865.2409 tbsp
910 kg = 61541.5213 tbsp
920 kg = 62217.8018 tbsp
930 kg = 62894.0822 tbsp
940 kg = 63570.3627 tbsp
950 kg = 64246.6431 tbsp
960 kg = 64922.9236 tbsp
970 kg = 65599.204 tbsp
980 kg = 66275.4845 tbsp
990 kg = 66951.7649 tbsp
1000 kg = 67628.0454 tbsp 1 kilogram (kg) = 67.628045403686 tablespoon(tbsp). Kilogram (kg) is a unit of Weight used in Metric system. Tablespoon (tbsp) is a unit of Volume used in Cooking system.Please note this is weight to volume conversion, this conversion is valid only for pure water at temperature 4 °C.
1 US cup = 16 US tbsp.
US oz = 28.349523125 g
US fl oz = 29.5735295625 ml (milliliters) = 29.5735295625 g (grams) of pure water at temperature 4 °C.
US cup = 8 fl oz = 236.5882365 ml (milliliters) = 236.5882365 g (grams) of pure water at temperature 4 °C.
Kilograms also can be marked as kilogrammesin UK. US tablespoon can be abbreviated as T, tb, tbs, tbsp, tblsp, or tblspn.
For Assignment Help and Writing services in Mathematics visit :
All Assignment Help and Solutions Best Assignment Help
Mar 29, 2018 • Homework
Convert kg to cubic meters how many kg to one cubic meter
Kilogram is a unit of mass (or weight). Cubic meter is a unit of volume. There is no direct conversion between them.
A cubic meter of water weighs 1000 kilograms. A cubic meter of gold weighs nearly 20,000 kilograms.
1helpful
Kilos to stones conversion
1 stone = 6.35029 kg 1 kg = 0.157473 stone
http://www.metric-conversions.org/weight/kilograms-to-stones.htm
Cannot get it to simply read weight in pounds
Hi dave,
Here is the Simple example of converting weight to pounds.
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Hope it helps.
Thank you for using fixya.
Give the equivalent measure of 500 grams to kilograms
Hi.
1Kg=1000 grams.
Therefore:
500 grams = 1/2 Kg = 0.5 Kg
2helpful
2answers
Convert metric weight to pounds
Good luck.
1helpful
Weight of 8 litres in pounds
You can't convert litres to pounds, at least not directly. The litre is a volume measurement, not one of weight (mass, actually). A litre of one material may not have the same mass as a litre of a different material, so a simple conversion factor doesn't exist.
If you know the specific gravity of the material you want to measure, you can convert the volume to a weight. Water is defined to have a specific gravity of 1.0, and 1L of water = 1 kg. One kilogram is approximately 2.2 pounds (you can look up the conversion factor if you need more accuracy). So if you are dealing with water, 8 L is around 17.6 pounds.
If you aren't measuring water, find the specific gravity of your material, and multiply by that value. A liquid with a specific gravity of 0.75, for example, would have mass of 0.75 kg per litre, so 8 L of that material would weight 0.75 times (or 75%) of 17.6 pounds. But without that specific gravity figure, you can't convert litres to pounds.
1helpful
2answers
What is the conversion of Kg water to Kg petrol
One KG of water is one liter, one KG Petrol is approx 1.356 liters.
Or one liter of water weighs One KG and 1 liter of Petrol weighs 0.737 KG at 60F
Grand Canyon Tech
Grand Canyon Tech
