Question about Alsons Home
I need an obsoolete part for an Alsons hand held shower system
The part is a metal swivel connector that has the pin as part of the connector. The pin fits into the part that slides up and down the bar. The hole that it fits into is 1/4 inch in diameter. The pin is embedded in an acrylic piece that bolts onto the hand held shower. The acrylic piece snapped off. I called Alsons and Nancy, who has worked in customer service for 17 years, said that she has not seen such a piece in all of her years with the company. As far as she knows no one has the piece.
    Novelist:
  • 148 Answers
Contact Trayco in florence Sc
They provide parts for all types of plumbing parts to the hotel trade etc
Toll Free 1-800-749-1120. Local (843) 669-5462 .
Good Luck
Posted on Dec 31, 2008
How do I change a single diverter to a 3 way diverter?
Not exactly sure what you are attempting. A quick-and relatively inexpensive way-would be to add an Alsons diverter to the shower arm. It is simply removing the shower head, adding the diverter, and reinstalling the shower head and accessory hand held shower. If you are looking for something different, there are myriad valves on the market that would allow for such change. However, changing to a new valve could get somewhat complicated. For example: you may need to increase the size of the supply lines that are feeding the shower; some diverters require a 3/4" feed.
Also, if you check the box stores, they have several shower/hand held shower kits that already have the diverter with the packaging. Again, I am not exactly sure of the end result in which you seek, but I hope this helps some.
Oct 31, 2014 | Dmm Symmons Temptrol pressure balancing...
Do you need plumbers tape where the handheld shower connects to the hose?
No tape is needed. As a matter of fact, taping the threads will make it harder for the swivel nuts on either end of your hose to tighten down and seal on the black washers that are supposed to be inside those nuts. It's exactly the same as a garden hose connection. No tape required.
Aug 07, 2014 | Oxygenics Hand Held Multi Function Shower...
Shower hose keeps disconnecting from metal connector
It seems you may need a new hose. You can contact Hansgrohe Tech at 1-800-334-0455 and we can handle the replacement for you.
Apr 10, 2013 | Hansgrohe 28274000 Techniflex 80in....
Install grohe shower bar
After removing from wall by unscrewing long screws after removing cap, look inside and you will see a white translucent plastic with 4 wide, flat hooked ends. Take a small screwdriver and gently push each 4 plastic hooked ends and it will come unhooked from the small groove. Push it far enough that the bar will slide out. No need to remove the plastic hooked piece. To replace, push in each hooked end and push in from the opposite end to reinstall.
Oct 14, 2012 | Grohe 24'' Relexa Shower Bar with Swivel...
When we hang up the handheld showerhead the
It depends on the model you have. Most have a large "nut" that will tighten down on the ball swivel. It should have finger grips. Tighten that nut some (clockwise) and it should get much stiffer.
Jul 04, 2010 | Water Pik WaterPik& Ecoflow Hand Held...
Its having some leaking how can i stop that?
If Leaking from the hose connection you can replace the washer, which you can get at any plumbing/hardware store. If leaking around the head area depending on the make and model, most always in the cheaper ones you just have to replace the whole head. Thank You for using FIXYA, good luck. Jeff
Mar 21, 2010 | Alsons Delta Seven-Spray Massage Hand...
Low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Dec 20, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Exact same problem.
if you call grohe they will probably send you a free one if it hasn't been over their warrenty period
Aug 01, 2009 | Grohe 24'' Relexa Shower Bar with Swivel...
Grohe 24'' Relexa Shower Swivel Hand Shower Holder broke!
Try going to this web page and looking up the nearest parts carrier in your area.
http://www.groheamerica.com/t/25_3859.html
sanray
Dec 28, 2008 | Grohe 24'' Relexa Shower Bar with Swivel...
Home Logo
180 people viewed this question
Top Alsons Home Experts
john h
Tom Chichester
Are you an Alsons Home Expert? Answer questions, earn points and help others
