Question about Panasonic Office Equipment & Supplies
My Panasonic AS-300NN Commercial Electric Stapler always staples from 2-3 times instead of once.
3 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: We have a Panasonic AS-300N
Yes the plastic lever triggers the sensor, it may not be going back in place. It is supposed to have a spring like action, so that when you remove the paper it goes back to it's original position. check and see if it gets stuck, or maybe try blowing on the sensor , could be dirty.
Posted on Sep 17, 2008
  • 2072 Answers
SOURCE: AS 300 electric stapler--pulled out
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Posted on Sep 28, 2008
Where can I get a couple Panasonic AS-500 Commercial Staplers repaired? Have tried calling Panasonic at 1-800-405-0652 option 4 but got nowhere.
This is a rather rare request, as very few places fix staplers.
I should recommend you find a "handy-man", maybe an older person with a hobby, and he may be able to help you.
I fix staplers, but have only been successful about 50% of the time.
God bless your efforts.
Feb 25, 2016 | Panasonic AS-500 Commercial High-Capacity...
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
The spring that loads the staples for stapling broke in half where can I buy a new or used one
  1. Panasonic AS-300NN-A Panasonic Commercial Electric ...
    electricandbatteryofficestaplers.julietshop.tk/panasonic-as-300nn-a-panas...Mar 19, 2015 - Commercial-grade electric stapler with 25-sheet capacity features jam-free operation, auto-reverse, adjustable stapling position and LED status ...
Jul 11, 2015 | Panasonic As 300NN A Commercial Grade...
Stapler malfunction
I don't know, but check how frequently the stapler jams.
Dec 10, 2013 | Panasonic AS-302NN Electric Stapler Heavy...
How do I open the staple compartment? Already tried the back button
Pushing the button should eject the staple compartment from the front of the unit. It sounds as if the stapler compartment is jammed or corroded.
While pushing the button, attempt to pull the compartment from the front of the stapler. It should slide out like a drawer. Try pulling on the front of the compartment while applying a little pressure in different directions.
You may have to use a small tool to grab the compartment if you can't get a good grip. You may have to use some force. Use only as much pressure as you're comfortable with.
When you do open the compartment, inspect all moving parts and bearing points to be sure nothing is jammed, bent, corroded or seeing excess wear. Remove a jam with small pliers, being sure to get the entire staple. Use fine sand paper on corrosion and then treat with a bit of oil.
Sep 08, 2011 | Panasonic As 300NN A Commercial Grade...
Panosonic Electric Stapler does not staple paper!
It could be either jammed up with staples or the spring mechanism is shoddy.
Apr 14, 2009 | Office Equipment & Supplies
AS 300 electric stapler--pulled out jammed staples but even though it staples, it won't grab the staples (staples as though empty)
Sep 28, 2008 | Panasonic Office Equipment & Supplies
We have a Panasonic AS-300N electric stapler that only works some of the time. When it doesn't work, we put the paper in the slot and nothing happens. Sometimes if we unplug it and plug it back in, it will...
Sep 16, 2008 | Panasonic Office Equipment & Supplies
342 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
