Question about Sony SVR-3000 TiVo
Sony SVR3000 Deleting everything a restarting the tivo box
I have not been using my tivo for a couple of months so i pushed the option that says delete everything and start over and the machine restarted and now it is stuck on a screen that says: Clearing and deleting everything this can take upto an hour. Well its been 8 hrs now and I cant do anything but to unplug it and when it starts agin it goes back to the same screen and gets stuck there again. The orange light that says connecting is blinking but nothing happens. Any suggestions? I appreciate your feedbacks.
    Scholar:
  • 27 Answers
Assuming this is a real TIVO and not an NDS DVR which are sometimes called "TIVO's". The delete everything and start over in effect reinitializes (or formats) the Hard Disk Drive. Since many problems can be attributed to software, this is making the assumption it IS a software issue. If the system kernel and/or associated utilities or the MFS file system are in some manner corrupted, they would give you this hang indication. The Drive would have to be reformatted and the kenel would have to be reinstalled. This is a tedious process that must be performed on a computer running the Linux OS since the TIVO OS is Linux based. There are several internet resources that have free software to download to perform this process. If you have no other TIVO drive to swap out to check that this is the issue, you could buy a new preformatted and loaded drive for your system. www.weaknees.com is a reliable source for TIVO replacement drives and are resonable. Hope this helps.
Posted on Jan 30, 2007
SOURCE:
Sony DSC-W320 says "no space on memory card" even though it's completely empty
The problem most likely is caused because you are deleting EVERYTHING. Next time, instead of deleting everything, format the card in the camera instead.
May 13, 2012 | Sony Cyber-shot DSC-W50 Digital Camera
For the last couple of days every time I try to do anything on my Blackberry I get a small black square in the middle of the screen that looks like a clock face, it has a what looks like the hand of a...
Please try resetting the phone.But please backup all the data because this process will erase everything.
CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts.
  1. On the Home screen or in a folder, click the Options icon.
  2. Click Security Options.
  3. Click Security Wipe.
  4. Perform any of the following actions:
  • To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box.
  • To delete all third-party applications that you have added, select the User Installed Applications check box.
  • To delete all files from your media card, select the Media Card check box.
5. Type blackberry.
6. Click Wipe.
Mar 28, 2011 | RIM BlackBerry Curve 8520 Smartphone
NEW SAMSUNG CABLE BOX TIME WARNER &TIVO SERIES 2
the IR is located next to the power button and you will have to select pioneer as your cable box brand and it will work fine
Jul 28, 2010 | Samsung Televison & Video
Comcast cable channel one off from Tivo channel
I've never, ever heard of this problem - having been a happy TiVo user for over 15 years. The very first thing I would do is call Comcast and tell them what is occurring. How long had everything worked OK before this happened? If things were OK for a long time before this, and if your TV carrier was, likewise, Comcast for a long time; and if you haven't gotten a new TV or cable box for a long time, then the problem must rest with Comcast. It must!
In our home, with the number of movies, shows/sporting events/etc. which we record, that would be totally unacceptable!
Try this: Unplug everything (with everything turned off). Make sure your TiVo remote is good (fully charged batteries and the code is right for your TV/cable box), Wait for 10 minutes and plug everything back in, starting with TiVo, then the TV, then any other accessories.
Plug back in and do a complete restart from scratch - like you did when you first set up TiVo.
Make SURE that your receiving channel (3 or 4) is the same on both. It could be that someone accidentally has changed it - are there kids in the house?
If none of this works, get Comcast in there. That's all I can tell you. . .
JB
Apr 11, 2017 | Tivo Televison & Video
Hughes DirecTV TiVo SD-dvr80 quit working
the are some new features that tivo does not support. you still can watch your saved programs. Sadly the older tivos are equipped for the digital transitoins. I know Tivo and Directv are releasing a new receiver in a few months.
Jan 07, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
I can't get my tivo to change channels. It stays on the same channel
I believe that you are already on the right path, your tivo will still be assuming that you are running off the cable box plus you watch dancing with the stars for five minutes one time just to see Warren Sapp attempt to dance and now all of a sudden it wants to record every single piece of televison with dance in the title or discription, but I'm not bitter.
Just re-accomplish the set up and let it know that you are no longer running a cable box. Also tell it that ditching you friday night to hang with it's old high school buddies was so not cool.
Oct 03, 2008 | Pioneer DVR-810H DVD Recorder
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Non-HDMI Tivo connection
The solution I use is S-Video from cable box to TIVO, and from TIVO to TV. That gets you the highest quality signal that the TIVO can handle. To watch true HD signal, switch TV from S-Video input to Hi-Def input and tune to HD channel. I have an HD cable box connected to both outputs, your situation may be different.
Feel free to ask for more help.
Jeepster77
Jan 16, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony SVR-3000 TiVo Logo
327 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
