Question about Black & Decker AV1200 DustBuster Handheld Vacuum
Cyclonic 14.4 volt DustBuster started loud humming noise?!HELP
Had unit for 6 mos. no problems at all. rather like the vacuum . Recently used it to pic up some sawdust, not very much, and it now hums like a jumbo jet. Need to ask you if theres something i can do to fix. tried cleaning all filters and tapping unit to clean but still really hums? thanks for any help you can give me. Doug
Ours began making a hideous grinding racket and then quit altogether. Upon disassembly, I found a plastic guard protecting the fan that had warped and was preventing the motor from turning at all. Your problem may be related to the same plastic guard. I removed mine and now all is well...I think. If only I could find a replacement for this little guard. Every online parts distributor I've seen will only go as far as selling filters and prefilters.
Posted on May 15, 2009
1-year old dustbuster black decker cwv1408 will not run unless I slap it on left side.
Your description would suggest either loose wire or a short in the switch. Take the unit apart and check to see that battery terminals are tightly connected.
Jan 02, 2015 | Vacuums
Vacuum is loud
Check for clogs starting with the air passageway at the bottom....
a piece of TV cable is great for clearing clogs there....check all
hoses...check for dirty filters. If you find no clogs remove the
brush bar and belt and start the vacuum...if the vacuum is no
longer noisy the problem is the bearings at each end of the brush
bar..... WD 40 may fix or you will have to replace. If after all this
the noise persists the the problem is in the motor. (If you use WD 40
make sure it is dry before you vacuum carpet)
Regards,
Dennis
Aug 15, 2014 | Bissell 4104 Bagless Upright Cyclonic...
Loud humming dyson DC07
Hi Phil,
I apologize for our delayed response. I am sorry to hear you are experiencing an unusual noise when you initially run your DC07. Based on the details you provided we would appreciate the opportunity to trouble shoot with you over the phone so we can also hear the noise to better determine next steps.
At your earliest convenience, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (UK). We look forward to speaking with you.
Best wishes,
Jessica
Nov 28, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
Loud noise from brush roller
Hi its Darran at Dyson.
Maybe worth checking the brush bar and cleanerhead for a blockage or for any damage.
If you cannot find a problem, please call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Apr 14, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
Filters all seem clean and clear, suction is fine,but loud noise
Sounds to me it could be tha fan impellor.
This is vac's etc... email us if you need to.
vacs.etc@live.com
Nov 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
Aug 05, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 all floors.
sept 30,08 bought dc14 all flloor. After 3 to 4 uses it started making lots of noise when on carpet setting. I examined the roller brush and it was cracked at one end. I returned it Oct 13 ,08 and got another dc 14 all floor. Now this one after 2 uses has the same problem only a larger crack in the brush and a small piece of the brush broke off. Very dissapointed.
Jan 08, 2008 | Dyson DC14 All floors Bagless Upright...
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
Black & Decker hand held dustbuster
First make sure it's not the wall charger - use a meter or a flashlight bulb to test the 15 or so volts that should be on the contacts when the charger is plugged in but the unit is detached.
The next thing is to remove the filters and see how easily the "fan" spins - use a popsickle stick or something that won't break the plastic fan if you can't get your fingers on it. Tight bearings may indicate clogged with dust (or corrosion) or destroyed. Free bearings likely indicate a switch or battery problem (good motor.)
Nov 12, 2007 | Black & Decker CHV1500 Bagless Handheld...
Black & Decker AV1200 DustBuster Handheld Vacuum Logo
402 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
