Question about Kenmore 24032\24036 Top Load Washer
Kenmore Model# 110.25842400
My washing machine fills up with water but does nothing after that. I have read that it may be my lid switch. I am wondering if the part #3949238 can work for my Kenmore. It says it is a whirlpool part. I also want to know if it is not the lid switch, what else can I check for?
  • 2 more comments
  • missawissa68 Nov 20, 2008
    What part number is the timer?
  • missawissa68 Nov 21, 2008
    Model# 110.25842400
  • gberwald May 25, 2009
    Washer fills with water but then shuts down and will not run.
  • Anonymous May 26, 2009
    top lid switch not working I need to know how to replace it ?
  • 370 Answers
Yes that is the correct lidswitch. (i checked via model # on sears.com) Before you replace the switch, Turn the washer manually into spin and see if it will. If it spins your lid switch is ok. If there is a humming after the washer fills then your motor is bad. It trys to work but cant. if it does nothing after it fills then you have a bad timer most likely. But see if it will spin when you turn the timer to spin manually.
Posted on Nov 20, 2008
  • Justin Duby
    Justin Duby Nov 20, 2008
    What is the model number for your machine. When i get the model number i can gice you the part number.
  • Justin Duby
    Justin Duby Nov 21, 2008
    8557393
2 Suggested Answers
AlmostBob
  • 550 Answers
SOURCE: Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Posted on Aug 29, 2008
Kenmore top loader mod. 110 29522801 does not run after filling with water. The lid switch could be bad. Are there other problems that should be addressed?
if the unit is filling with water it is not the lid switch because it will not fill with water if the lid is open
problem areas are the water level switch is not energizing the wash cycle as well as switching off the incoming water
if it is stopping the water but nothing else , have a technician check the program board
Jan 13, 2017 | Kenmore Washing Machines
Fills with water will not run no motor sound nothing
top load or front load .might be the lid switch /door switch . or the control board make,and model usually helps us help you
Oct 24, 2015 | Kenmore Washing Machines
Kenmore 300 model 110.28322700 won't run. motor makes humming sound
Pre Thanks for help.
I have read all above and these are my symptoms.
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
however i tested my lid switch with a multimeter and the lid switch seems to be fine.
What else could be my issue?
Kenmore 300 110.28322700
Dec 03, 2011 | Washing Machines
Fills with water and then nothing kenmore washer model 23822100 type 111
Top load machines will fill with water while the lid is open. Your problem starts when you close your lid. NOTHING happens. I believe this to be your LID SWITCH . Replace or have replaced and you should be OK. GOOD LUCK.
Jul 26, 2011 | Kenmore 23822 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
923 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
