Question about Sharp 25R-S100 25" TV
Too loud I had digital cable installed and now the volume will not change at all the volume is all the way down and it is still very loud.Never had this problem before
    Sergeant:
  • 308 Answers
I am assuming you do not have a "surround sound" system hooked up to your digital cable box, and that you have your TV volume turned down all the way and have not yet tried to adjust the volume on your new digital cable box. It might be worth a try to unplug your TV for about 15 seconds and try again. If the above is true and you can still not lower the volume through the cable box or the TV set, then I would have the cable people stop by to check it out.
Posted on Dec 18, 2006
The sound/volume is not working properly on our Bose 321 system...i.e., whereas, a "normal" volume at (let's say) 35-40 is way loud, but now have to turn volume up to 100 (maximum) to be able to...
Make sure the device it is connected to has its audio properties setup correctly. If this is a cable or satellite box, most of them have a volume output level. Changing this will change overall volume.
Mar 01, 2011 | Bose 3 2 1 GSX System
How to change the volume on my naxa nx 144 mp3 player
You can change the volume of your naxa nx 144 video player by;
1.Pressing and then holding down the VOL Button for about four to five seconds
2.After you do that you will see the number near the center of the bottom of the screen on the player's screen start to blink or flash.
3.When it is still flashing press the |<< O >>| or what some people including myself call the Rewind or Fast Forward buttons until the number that is still flashing on the bottom of the screen is a diffirent number then when it was when it started flashing earlier.
4. After you change the still flashing number for the player's volume until you get it as loud or as quiet as you desire repeat the first step by holding down the VOL Button once again for about four or five seconds and....v`iola it should be adjusted to your liking now.
Oh yeah before I forget here is a friendly word of advice for you. DO NOT FORGET and leave the volume on real loud and then play your song,video or,ect. before turning you volume back down because it will be REALLY LOUD and REALLY PAINFUL ON YOU EARS.
Thank You and I hope this helps for you.
May 14, 2010 | Audio Players & Recorders
Tivoli Model one radio - volume control does not go to quiet. I like to listen at night but volume does not lessen past a certain point which is too loud.
I noticed the same problem after I had moved. Hadn't had it before. The solution was easy in my case. (It took some time to accidentally figure it out though). I flipped the power cable around 180 degrees / upside down and re-connected. After this the volume worked as before. This was the model with European power plug.
Mar 01, 2009 | Tivoli Kloss Model One AM/FM Radio
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Sound won't turn down
Change out your audio cables ,if this does not work some where you are missing ground.or its not connected right.ThankYou for using FixYa. Have a Nice Day.
Feb 17, 2008 | Toshiba 51H83 51" Rear Projection...
Sharp 25R-S100 25" TV Logo
82 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
