Question about Imperial IFS50 Deep Fryer
Thermostat broken Is there anywhere in Ireland where I can buy a replacement thermostat for an Imperial Fryer.
  • 21 Answers
Try this company i think they will ship anywhere ICS 1800 243 1290 ext 4226 ( Scott)
Posted on Nov 21, 2008
Why does fryer shut down when it hits 200 degrees
The thermostat? If your thermostat works normal, it should switch off the heater when the temperature is reached. Perhaps there is a last security, when it really gets to hot it will trip and you have can't use it till that is repaired. Perhaps you replace the thermostat. Or if a new thermostat is almost as expensive as a new fryer, buy a new fryer.
Jul 17, 2014 | Imperial Kitchen Appliances - Others
What is causing my imperial fryer to burn my fries when the thermostat se at 300 this wasb not happening before
Sounds like your thermostat is not calibrated properly. this is a job for a pro. If you don't do this correctly the grease temps can rise above safe levels and cause the high limit to open.
Jul 11, 2014 | Imperial IFS40 Deep Fryer
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 30, 2012 | Imperial IFS40 Deep Fryer
Imperial gas 40 lb fryer, replaced thermostat, now when you set the dial at 250 the oil heats above 375 and keeps climbing. What now?
Sounds like you have installed the wrong thermostat, or it's a bad one... If you need further help, please call us at 888-542-5959. If you have the model/serial number, we can make sure you have the right thermostat and/or get you the right one... Thanks, Susan REO reocincinnati@yahoo.com
Aug 23, 2011 | Imperial IFS40 Deep Fryer
What do i use to jump the thermostat on an imperial fryer?
Touch the two terminals with a wire, if the fryer comes on, then you have a bad thermostat...If that's not it. it could be high limit...If we can help in any other way, call us at 888-542-5959, Restaurant Equipment Outlet, Cincinnati, OH or www.restaurantequipmentinc.com
Aug 22, 2011 | Imperial IFS40 Deep Fryer
Imperial IFS-40 fryer. Pilot is lit, but buriners won't come on when the temp dial is turned from off to any degree.
Sounds like your thermostat is bad? We could order you one, however in order to get you a price, I need the serial number also. These are very common fryers,our best seller by far and a good fryer too. But, things happen, and the thermostat is the most common part that is replaced after some time....
Our phone is 888-542-5959, Restaurant Equipment Outlet, Cincinnati, Ohio. We ship parts in 1-2 days, and I can get you a price in a few minutes time, if you call or email me. Thanks, Susan REO
Jul 09, 2011 | Imperial IFS40 Deep Fryer
Hello,I have a Imperial IFS deep fryer S#06301407 .We had a pinhole repaired in tank.I know that tank was removed prior to repair .Unit did work fine other than leak before tank repair.After lighting pilot...
You can use a jumper wire to test the valve. The voltage is LESS than 1 volt so do not worry. Imperial fryers usually use a robershaw gas valve. the 2 outside terminals...left and right.... are where the thermostat connects. Using a jumper wire after the pilot is lit will tell you if the valve is good or if it's the thermostat. You can also use a multimeter and check the continuity of the thermostat.
Tom
Jun 08, 2010 | Imperial IFS40 Deep Fryer
Imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Oct 19, 2009 | Imperial IFS40 Deep Fryer
Fryer coming on without turning thermostat on
Imperial Model: IFS-40.
The thermostat is either very far out of calibration or has failed, either case it should be relplaced. The Imperial Part # for the thermostat is 1175.
May 04, 2009 | Imperial IFS40 Deep Fryer
Looking for a thermostat unit for the Imperial IFS-40 serie : 05159306 what's the part number??
If you have a manual thermostat,(inside door, knob) your part is
#1175 OPERATING THERMOSTAT (HERMETICALLY SEALED REED SWITCH)
If you need the Hi-limit t-stat --
#1177 HI-LIMIT SWITCH
If you have digital control, with digital temperature control, the unit uses a probe.
#1094 FRYER CONTROLLER TEMPERATURE PROBE
Good luck, Mike
Jun 06, 2008 | Imperial IFS40 Deep Fryer
Imperial IFS50 Deep Fryer Logo
82 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Joseph Hoffmann
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
