My Dell laptop will not boot up
I have turned it on in over a year. It says no boot device avilable go to F2 for setup utility. I did that and re-set the clock & calander when I go back and hit F1 it displays no bootable devices{s} selected.
  • ragsreddy Jan 02, 2009
    Hey even i am having the same problem...any help
  • seadragon200 Mar 18, 2009
    installed new hard drive it says no bootable device
  • 903 Answers
Make sure that there is no cd inside the cd rom or floppy in the drive (if your laptop has a floppy drive),
Then go back to bios (F2), and choose your hard drive as priority boot option 1, save and exit.
As you computer boots up press F8 to get an option screen on how you want to start windows, select Last good known configuration. Hopefully this will boot your laptop.
Posted on Nov 20, 2008
I have difficult to boot the laptop when i switch on display f2 to enter when i pres f2 it's showing setup utility please help me to boot the my laptop please thanks
If you leave it and don't select F2, it should carry on and boot, if not go to the bios setup and make sure the boot device is correct.
May 29, 2016 | Computers & Internet
Error code: 1000-0143
I would suspect hdd errors and replace the drive.
Sep 06, 2014 | Dell Computers & Internet
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
When i turn on my laptop it is telling me that there is no internal hard disk drive not found. To resolve this issue try to reseat the drive. Then it tells me there are no bootable devices--strike F1 to...
This seems the Hdd is Not getting Detected , First thing you can try is inserting the hdd back in the system and then get into Setup Utility by Pressing F2 and check whether the hdd is listed or not , If the HDD is not listed that means HDD has gone bad .you need to get a new HDD
Aug 29, 2010 | Dell Inspiron 1525 Notebook
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Everytime we boot up our computer it says press f1 to do something and f2 to enter setup mode?
generally an indication that something is wrong in the system setup. Press F2 and enter setup, check the time and date settings and the system event log (If BIOS has one) for incorrect settings, also check and see if the BIOS shows a hard drive installed.
If time and are wrong, set them to correct and save settings. If system keeps losing time and date after power is removed, then the backup battery may need to be replaced.
If HDD is not detected, then reseat it. If still not detected replace it.
Dec 10, 2009 | Dell Inspiron 600m 1.6GHz Pentium M...
Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Oct 27, 2009 | Dell Inspiron 1521 Laptop
Hard drive issues
This can happen if you leave a CD/DVD in the drive, a flash drive, memory (flash) card, etc connected to your computer when you first turn it on.
If that isn't it and the hard drives are good (I think we can assume this), then you must go into the Setup Utility (also called BIOS Setup). And setup and tell it you have a hard drive connected. Otherwise it won't see it.
If that doesn't work, this now doesn't sound good. As you then need a new controller. Which means a new motherboard.
Jan 30, 2009 | Dell Inspiron 6000 Notebook
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Computers & Internet Logo
691 people viewed this question
David Payne
David Payne
