Question about Hannspree SD02201100
My BRAVIA Full HD TV model KDL-40L4000 keeps deleting my channels
Each time i install my channels it fails to install at least 10 program channels like itv1, 2,3 channel 4,c4 +1 more 4 i can find and manually install them but then about 20 minutes later the picture will start to lose signal then the picture will stop but i can still hear the program and a note will appear at the top of screen " this channel is not tuned in " then the rest of the channels will also stop working in the same manner I am at a loss as i can't locate my troubleshooter book. I hope it is something simple.
Hope you can help MR P. SPELLMAN
5 Suggested Answers
linswad
  • 258 Answers
SOURCE: My picture keeps going dark. What can I do to fix
Just throwing some ideas in here:
Is the picture still visible, just much darker?
Are you using it as a TV or monitor? If it's a monitor try it on another PC.
Does the same thing happen no matter what input you're using?
Is it overheating somehow?
Maybe try changing the sleep setting to 30 or 60 mins and see if there's any difference, in case there's a problem with that section. (Not that you can fix it if there is.)
Worst case scenario, the TV is faulty - if the backlight is actually going off, the picture would still be there but barely visible. But if you've just bought it there should be no problem about getting a replacement.
Posted on Apr 04, 2010
Testimonial: "I figured it out. It was the X-control. The TV came with that setting turned on. As soon as I turned it off, the dimming problem stopped. Thanks!"
  • 44 Answers
SOURCE: We have the 27 inch
Hi - My name is Tina and I am with Suddenlink. Are you receiving your channels over the air (without a cable box)? If so, that is the way they are broadcast over the air in digital/high definition from the broadcasters and without converting them (with a cable box) there isn't anything that can be done to fix this issue. If you add a cable box to your set, then the box can convert the channels without the dashes. Plase feel free to contact me directly at tina-AT-suddenlink-DOT-com for further assistance. Thank you.
Posted on Jul 26, 2011
SOURCE: Cant get subtitles to go
TV mode:
Open the menu and go to features then subtitle.
Switch off analogue subtitle.
Scroll to 1st subtitle and then scroll through the languages until "off" comes up.
Repeat for 2nd subtitle.
Hey presto... they gone!!!!!! :-)
Posted on Sep 15, 2011
vinceisaac
  • 2432 Answers
SOURCE: Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
Posted on Sep 07, 2012
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with...
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
Dec 01, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Feb 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How to improve picture quality?
are you using an hd source ? hd cable box, satelitte receiver or antenna with the digital channels programmed in. regular tv channels will not look as good as the picture you saw in the store when you bought it. they all use only high definition signals.
Dec 14, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hannspree SD02201100 Logo
81 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
