Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Video memory upgrade for an Acer Aspire 5100.
It's an Acer Aspire 5100. I have 2g ofRam and its the integrated Ati Radeon 1100, 256mb of video memory. Iwas hoping that with a new video card the 2g of ram wouldn't be such awaste. Can I upgrade my video card, and if so what is compatible.
Sorry, but if it has intergrated video as you say then video card is NOT upgradable, simply because it does not have a card (It is intergrated into motherboard). That unit can take up to 4GB of ram 2GBX2 DDR2 PC25300 200pin SODIMM $56.00@ crucial.com. It is able to share an dditional 256mb of memory from system for a total of 512mb memory on video. With a little research u should also be able to upgrade the cpu.
Hope this helps good luck,
Dave
Posted on Dec 07, 2008
    Sergeant:
    Champion:
  • 233 Answers
Sure, upgrading the video card to a more powerful one is always the best choice. If you want to play Games with intense graphics, surf the web at the same time working with documents and playing music all at once then consider buying it. It also prevents computer crashes.
Posted on Dec 03, 2008
2 Suggested Answers
  • 243 Answers
SOURCE: acer laptop upgrade
Need more info about laptop model number.
Ram and hd should be easy enough to upgrade but cpu unlikely and graphics very unlikely as its usually onboard vga.
Posted on Jan 19, 2008
Show video card Aspire 1691
I concur with Chris about this laptop model, (NOT that Chris needs me to concur)
If I may;
For the Aspire 1690 series of Notebook PC's, the graphics chipset is soldered directly to the motherboard.
There are models of laptops that DO indeed have a separate graphics, or video card. They use the MXM technology.
The Acer Aspire 1691wlmi Notebook PC, may have either the ATI Mobility Radeon X600 GPU, or the ATI Mobility Radeon X700 GPU.
(Graphics Processing Unit, or also known as the graphics chipset)
This is one example of the ATI Mobility Radeon X600 graphics chipset,
http://www.ebay.com/itm/1x-ATI-Mobility-Radeon-X600-216PDAGA23F-BGA-Chipset-/280796092668?pt=LH_DefaultDomain_0&hash=item4160c058fc
You are looking at a Top View, as it is mounted on the motherboard.
What you do not see is the method of mounting.
This graphics chipset is mounted to the motherboard, via a BGA surface mount.
Ball Grid Array.
To explain the BGA surface mount;
Compare to an older Intel Pentium 4 desktop processor, that uses a Socket 478 processor socket,
The processor has contact pins on the bottom of it's circuit board. 478 of 'em.
The processor socket has matching socket holes. (478),
http://en.wikipedia.org/wiki/Socket_478
With a BGA surface mount there are no contact pins, on the bottom of the graphics chipset, as used on an older Intel Pentium 4 processor. (That uses a Socket 478 processor socket)
There are no socket holes in a processor socket.
No socket on the motherboard.
In place of the contact pins, there are Solder Balls on the bottom of the graphics chipset.
In place of the socket holes in a socket on the motherboard, there are instead Copper Pads.
(The copper pads are also gold plated)
The graphics chipset is set down on the motherboard, with the Solder Balls lining up on the Copper Pads.
Heat is then applied at a specific temperature, and length of time.
This action melts the solder balls, and solders the graphics chipset to the copper pads.
(Thereby also soldering the graphics chipset TO the motherboard)
This example of one maker, of a SMT/BGA Rework Station at work, will help demonstrate the above method,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll the page down, click on the red -
Take a few minutes to view the IR 650 demo video
That's just the mechanical aspects of replacing/upgrading a GPU, using a BGA surface mount.
Now you need to look into what will work.
The motherboard chipset determines what hardware components, can be used on a motherboard.
The motherboard chipset, as used on the Acer Aspire 1690 series of Notebook PC's, uses a Northbridge chip, and a Southbridge chip.
(Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Integrated Circuit, or chipset, that is used for graphics, is the graphics chipset, or G.P.U.,
http://en.wikipedia.org/wiki/GPU )
The Northbridge chip handles the faster capabilities of a computer.
Handles the Processor, Ram Memory, and High-speed graphics.
A graphics chipset using the PCI bus is NOT high-speed graphics.
(Such as a PCI graphics card inserted into a PCI slot, on a desktop computer motherboard)
Integrated graphics is also Not high-speed graphics.
High-speed graphics uses an AGP bus, or a PCI-Express bus.
The ATI Mobility Radeon X600, and X700 graphics chipset, on the Acer Aspire 1690 series of Notebook PC's, uses a PCI Express x16 bus,
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Mobility_Radeon_X300.2C_X600.2C_X700.2C_X800_Series
IF, your Aspire 1690 series Notebook PC, uses an ATI Mobility Radeon X600 graphics chipset, and you wanted to upgrade to an ATI Mobility Radeon X700 graphics chipset, it would not be worth your trouble.
By the time you buy the X700 chipset, have the X600 removed, and X700 installed, it would be cheaper, and wiser to just buy a better laptop.
[ One I bought for work to use on Electronic Technical Manual's, is an Acer Aspire 5552-3691
1) AMD Athlon II X2 P340 (Dual Core) processor
2) 4GB of DDR3 Sdram (SO-DIMM) ram memory at 1066MHz
3) ATI Mobility Radeon HD 4250 graphics chipset.
Price? $398.00USD.
Not the best by FAR. But MUCH better than what you have presently.
Just food for thought ]
Just thought you would like to know why, it isn't feasible to try to upgrade the graphics chipset.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 06, 2012 | Acer Aspire 1691WLMi PC Notebook
My geforce 8200 can not play fifa 11
Your graphics card is below the game minimum requirements (see link below) I would guess that this was a Dell, HP or other, and yours is basically a stripped down card with missing features, less memory etc. (which is why FIFA doesn't work) Your game also requires shader model 3.0, which will be present in all retail video cards on the list below.
From my information source site:
" Please note that NVIDIA GeForce 7300,8100,8200,8300 and 9300, ATI Radeon HD3200, HD4350, and Intel / S3 integrated chipsets are below minimum system requirement ."
http://gamesystemrequirements.com/games.php?id=956
If this is a desktop system, you can upgrade your video card to one of the following chipsets (video card series)
"Recommended Chipsets: NVIDIA GeForce® 6xxx series (6800 or greater) NVIDIA GeForce® 7xxx series NVIDIA GeForce® 8xxx series NVIDIA GeForce® 9xxx series NVIDIA GeForce® GTX 2xx series ATI Radeon X1600 (X1600 or greater) ATI Radeon X1800 ATI Radeon X1900 ATI Radeon X1950 ATI Radeon HD 2xxx series ATI Radeon HD 3xxx series ATI Radeon HD 4xxx series.
If you need help choosing a new video card, please repost your question and include the make (Dell, HP, etc. or white box) and model #. If this is a DIY project then please include as much information as possible about the mainboard, what version of windows, power supply, etc..
Once you know what you need I would check out newegg.com for video cards. They will have what you need at the best prices...
Feel free to contact me directly if you would like continued help with this.
Aug 02, 2011 | Computers & Internet
Can i connect a video card on my acer aspire 5740?
i think you can, but this laptop has great integrated graphic card, it use Integrated Intel® HD Graphics or Discrete ATI Radeon™ HD 5650 graphics or Discrete ATI Radeon™ HD 5470 graphics
this graphic card can make great picture for HD video
Feb 05, 2011 | Lifetime Acer Aspire 5740 Replacement...
Integrated video card and second card don't work simultaneously
Not all mobo's can do this. The motherboard integrated graphics needs to be by ATI and you need to see if your motherboard supports hybrid crossfire. If the built in graphics is not ATI, they will not work together.
Nov 03, 2009 | Acer Computers & Internet
I have a t180 and it has the factory NVIDIA
Your machine has integrated video. According to the specs you can upgrade using the PCI-Ex16 expansion slot. The ATI Radeon you listed should work for you...
Feb 20, 2009 | Acer Aspire™ T180 PC Desktop
Getdata
http://www.laptops-drivers.com/acer-notebooks/acer-aspire-4315-download-driver-for-windows-xp.html
u see here al your laptop driver just download ati vga driver just lick and save on.
Feb 07, 2009 | Acer Aspire 4315 Notebook
I have a acer aspire 5100. I'm running vista sp1 ultimate 64x I have 4 gb of ram I'm having a very difficult time trying to plat Knights of the Old Republic (a game from 2000) I have a ati radeon xpress...
This model comes in 2 different flavors and I am unsure which one you have but here's the skinny on it:
Option 1:
ATI Radeon® Xpress 1100 chipset with integrated 3D
graphics, up to 256 MB of shared system memory
Option 2:
• ATI Mobility™ Radeon® X1300/X1600 with up to 512MB of
HyperMemory™ (64MB of dedicated GDDR2 VRAM;
up to 448MB of shared system memory), supporting
Regardless of which one you have, you should be able to set the shared memory in the BIOS, or you can use the Acer ePerformance Management software either installed on your machine already, or which can easily be downloaded from their website at this link:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Cheers!
-E
Jan 02, 2009 | Acer Aspire 5100 Notebook
I have an acer aspire 1355xc {1350 series} notebook no video card
It's pretty common for notebooks to have 'integrated graphics' which can't be modified or replaced since they are part of the mother board and normally also share memory with other functions. Only higher end units aimed at gamers are equipped with video graphics hardware that can be replaced to upgrade.
If you would like to give your system a boost, consider adding some RAM; it is pretty cheap and then the 'stolen' 64 MB of memory used by the graphics chips is no longer a bottleneck.
"The second omission is that of a separate graphics card. Playing sophisticated 3D games is becoming a reality with a lot of the latest mobile chipsets, but certainly not yet for people on a budget, those days are still some way off. Instead, what Acer has supplied is an integrated S3 Savage 8 graphics core, which shares 64MB of the system memory."
Acer review with details
Dec 07, 2008 | Acer Aspire 5610-4648 Notebook
Possible Video problem with Acer Aspire 5102.
are the fans running??
could be slight heat problem.
google for speedfan.
a utility to control fan speed on most laptops
Feb 01, 2008 | Acer Aspire 5100 Notebook
Help
Open Control Panel, Open Display. Click on settings. Change Color quality to 32bit. This link shows your specifications sheet.
This is for the 5100 Series
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=456&formid=3404&website=AcerPanAm.com/us&siteid=7293&words=all&keywords=&areaid=7
Click below to upgrade your video card. Select: Windows Vista 32-Bit Edition. Than choose: Integrated/motherboard. Than pick: Radeon Xpress 1100.
http://ati.amd.com/support/driver.html
This should put some perk back in the coffee pot!
please vote...
Jan 16, 2008 | Acer Aspire 3610 Notebook
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
1,865 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
