Question about Philips 60PP9401 60" Rear Projection Television
Phillips 60pp9401 my tv looks like a 3D movie.. its looks like my tv is in three sections.. when facing.. the left and middle are blurry like a 3D movie.. the right is tottally fine. i have no idea how it happened just started one day.. any ideas on something a i could do.. thanks Angie
    Sergeant:
  • 308 Answers
This set uses two convergence packs that go bad and take with them a resistor or two. You will need a repar shop to get it fixed. If it's over 10 years old, I would suggest getting a new HDTV set as these sets can start going downhill fairly rapidly past this age. If that's not an option, the repair could run over $350 IMHO.
Posted on Dec 18, 2006
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
I have a phillips 60 in rear projection tv model #60PP9401. and it is exhibiting the appearance of double vision, can this be fixed economically
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
HI I HAVE A 73 INCH 3D TV I BOUGHT A FEW MONTHS AGO-- ORDERED A 3D MOVIE CHRISTMAS CAROL-- INVESTED IN A BLUE RAY THREE D PLAYER-- AND I AM UNABLE TO WATCH ANYTHING IN 3D I FEEL I KEEP SPENDING...
3D in tv technology wright now are in it infincy.Not worth the money to buy the 3D LED tv and it 3D external devices.Right now are very limited in productions in movies in 3D world or 3D movies for tv or transfer from 3D movies from the movies theather Big Screen.Right now,just best to watch 3D movies in the theather Big Screen.Stick to a 2 dementional LCD tv screen for at lest another 5 years,before there are 3D tvs and movies,will make a difference in ur lives.
Dec 04, 2010 | Televison & Video
How do you fix a 52" hdtv ready when its in 3D blurry format
This tv doesn't have 3D capabilities - the image appears blurry because both images are displayed on the same screen at the same time. Just don't use the 3D option from the BluRay player, view the movie normally - 2D.
Jun 13, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lines, a little blurry, a little movement
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 10, 2010 | Hitachi 51F59 51" HDTV Projection...
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Phillips 60pp9401
Yes,generic will work, mirror material is nothing special, just get
the size right................
Original problem is convergence issue....do you still need solution ? ...................................T.
Sep 17, 2007 | Philips 60PP9401 60" Rear Projection...
Philips 60PP9401 60" Rear Projection Television Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
