We have a digimate 32" ltv-3203h the remote control has stopped working the tv but remote control is working fine. now when you turn the tv on by the buttons on the front of tv in the morning the green light comes on but no picture for half an hour or so also there is a squeeling from the sound for a while the tv has just gone 2 months out of warranty can you help please!!
    Top Expert:
  • Televison & ... Master
  • 12,962 Answers
SOURCE: blinking green light, no picture or sound
Probably the DM1 module has or is going bad.
Posted on Oct 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: I have a Samsung HLN467WX
I suggest going to the following link. they will have the service manual for your model available by email after purchase and they offer free tech support to help you with the diagnosis and repair of your DLP heres the link in case you want it.
http://servicemanuals.vstore.ca/
Posted on Apr 25, 2008
  • 4 Answers
SOURCE: NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
taran_2005
  • 10515 Answers
SOURCE: My mitsubishi ws65807 remote stopped
the first three flashes when the set is plugged in indicate whether or not the microprocessor has initialized. The sections involved are the microprocessor, the standby power supply, and the buttons, LED, etc.
The most common causes I have found are the standby power supply, the front panel assembly, and CRT fluid leakage. Are you comfortable working inside the set? This may or may not involve measuring live voltages with a multimeter
If yes, the first step a technician would take is to remove the speaker grill(s) and then the front cover at the bottom. A quick check of the front panel is to simply follow the wires from the bottom of the screen assembly until you reach in-line connectors. Disconnect these (squeeze clip on the side of connectors) and then plug in the set and try the remote pointed at the screen. If the set powers up, then the front panel assembly is bad.
Also, inside the front, view the PC boards for CRT fluid leakage. The fluid is (originally) clear and is slightly thicker than water. Any fluid whatsoever, even a drop, can cause damage to the PC board. The fluid will cause any dust in the set to discolor; this may make it easier to spot (please look very carefully).
The next step is to check the standby power supply accessed through the rear of the set. The main fuse is suspect (F9D00), although not likely if you are hearing a sound when the set is plugged in. Two other fuses to check are pico-fuses in the standby power supply (F9A01 and F9A06). These are located on the center (Power) PC board, near the center of the board, toward the rear. If either of these are bad, then there is likely another failure that caused it. Of course, if any fuse is changed, please use the same value only (I have the manual to look up the values if needed).
If all these are good, then the next step is voltage measurement of the standby power supply. I will pause here and wait to hear your results.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 13, 2009
SOURCE: RCA R52WH74 power light blinks but no power
i unfortunately cannot help you with your problem, but i have a question, how did you disconnect the front panel?
Posted on Dec 15, 2009
Directv code for digimate
I can help you with your Digimate TV & DirecTV remote control.
I do not see a code listing for Digimate TVs in the DirecTV Remote Control Manual.
But don't give up; many manufacturers reuse remote control codes. I recommend performing a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
May 10, 2010 | Digimate DGL2700 27 in. LCD Television
Digimate TV DGL20 REMOTE CONTROL
Use just about any remote and use the code for a Protron TV.
1) 0178
2) 0466
3) 0052
4) 0003
First one worked for my digimate 20"
Jun 14, 2008 | Digimate DGL20 Television
Sky remote code!!!!
did you ever get a code for this?
May 31, 2008 | Digimate DGL32 32 in. LCD Television
Problem with dvd playback on Digimate 3203h
On some LCD TV there is a filter for image correction, look in the TV menu and try to turn off this filter if available, also there might be a setting for full screen (stretch) and so on, play around with that.
hope this helps
Jan 07, 2008 | Digimate DGL32 32 in. LCD Television
Remote control code
I have a digimate dgl3201 lcd tv. i used code 070. they have the same codes used for protron tv's
Dec 29, 2007 | Digimate DGL20 Television
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
